My Maytag washer will not spin, it fills with water, agitates, drains but will not spin. I installed 2 new belts, the complete Lid Switch assembley but is stilll will not spin. What could be the problem now?
You need to operate it with the front panel off to see if the motor is turning during the spin cycle. If not, check out the wiring to the motor from the timer and try replacing the timer itself.
