I have amana alw480daw , belt burned up this morning and I would like to know why the belt burned up? :cool: Do you think the motor is gong out or the pump is bad ? How do I determin what the problem is, could you send me a diagram on how to replace belt?
Either a bad pump, or bad tub bearings, just check, most probably the pump.
Originally Posted by: richappy Either a bad pump, or bad tub bearings, just check, most probably the pump. rich checked pump and I can turn pully to pump and wheel under tub. turned on machine and water pumps into tub but unable to turn agitator in the tub. Should I be able to turn the agitator, keep inmind that I still havn't installed new belt. If I cant spin agitator would that mean the trans. is froze up?
I had the same problem. Do be aware that the belt needs to be a cloth covered belt to allow for slippage. If your trany is failed, it will be covered under waranty. If the main berring is failed, it is not. That's per Amana.
