The washer will fill and agitate but will not power spin and drain. Is it the timer control? can it be repaired?
Operate it with the front panel off and see if the motor is trying to turn when it should spin. Also check to see if the pump is getting voltage and if there is any obstruction in the internal hoses or something between the tub and basket.
If the motor and pump are not getting power then it may be the timer, which you can replace.
