Register | FAQ's | New Posts | Today's Posts | Extras |
» LG washer/dryer combo |
![]() Model Number: WM3431HS Brand: -other- Age: 1 - 5 years
![]() Washer Goes Thru Wash Cycle, But Then Wont Pump Out Water And Spin To Rinse, It Does Spin If Put On Spin Only But Does Not Pump Out Water, Pump Seem To Be Working It Is Making Nois And Spinning??? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hi. Get a bucket. place it in front of the unit under the lower trap door that is approx. 3" x 5". Once open you un hook the black drain tube that is cliped to the backside of the door. Uncap and pour into the bucket the excess basket water. Then re cap it and clip it back up. Then unscrew the front of the pump 2-1/2" pump cover and carefully slide the long cupped shelf attached to the back of this cover. It is there to trap the debris before entering the pump impellor. Then reach in and see if the impellor is losly spinning on the pump shaft. If it is then the pump is
Part number: AP4440742 . Make sure the drain hoser is not kinked or clogged. Thank You. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
washer/dryer combo | salvagesteve | Washer Repair | 3 | 09-05-2011 06:57 PM |
Washer/dryer combo | Shasta200619 | Washer Repair | 0 | 01-09-2011 12:42 PM |
washer dryer combo | Eddie365 | Washer Repair | 2 | 07-07-2010 09:50 PM |
Washer Dryer combo | motkerry | Dryer Repair | 1 | 06-04-2009 09:16 AM |
Combo Washer Dryer | marjoros | Washer Repair | 1 | 04-20-2009 06:28 AM |
