started with a bad transmission, replaced that, not it seems to work fine except it is still full of water when it starts to spin. the clothes of course are coming out wetter than before all this started. I've watched your videos and I think I put it back together right. What should I look for? I replaced the pump about 6 months ago and it seems to work fine. I just wonder if I have messed something up, while working on it.
If you are sure the pump is ok, pull the hoses off the pump and look for an obstruction in the hose from the tub or the hose from the pump.
