| » Kenmore elite washer is leaking under washer |
Model Number: 110-23032102 Brand: Kenmore Age: 1 - 5 years
There is water coming from underneath the washer. How do I remove the back panel? Any suggestions on what and where to look for the leak?
Thanks! Ads By Google Related Models |
Hi CBS
The back panel does not come off. Instead the cabinet comes off of the back panel. Look at the first three pictures on this site to see how to do it. Note: You console may have the screws in front, in back or under trim pieces, but they will be there. Kenmore top loader blues ‎(SublimeMasterJW's Appliance Advice)‎ You should see where the leak is coming from, most likely the pump which is center front. If so, take off the pump by removing the two clips and replace it. If it is from the center of the tub you will need to replace the tub seal. Good luck, let us know what you find
__________________
| Display Modes | |
| Kenmore Elite Washer Dead | Trebbor | Washer Repair | 3 | 10-02-2009 06:30 AM |
| Kenmore Elite Oasis HE Washer | bap2523 | Washer Repair | 0 | 09-09-2009 06:07 AM |
| Kenmore Elite Washer Leaking | Adams1206 | Washer Repair | 3 | 04-28-2009 04:53 AM |
| Kenmore elite washer is locked | PaulRC | Washer Repair | 8 | 11-13-2008 01:24 PM |
| Kenmore Elite Washer | skifrk | Washer Repair | 1 | 03-22-2008 06:03 AM |
