Discuss
Maytag Stem Seal/Tub Bearing
 in
Washer Repair
I purchased a stem seal, tub bearing and spanner wrench from your store. I also downloaded the repair manual (come
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Stem Seal/Tub Bearing
  #1 (permalink)
Old 01-03-2008, 07:31 PM
fabert fabert is offline
Junior Member
fabert is on a distinguished road
Default Maytag Stem Seal/Tub Bearing
Model Number: LAT9593AAL   Brand: Maytag   Age: More than 10 years
I also downloaded the repair manual (come to find out my model is not included) from your site
Tonight I worked on the washer and have 3 questions
1) Stem seal grease, what kind to use?
2) Stem seal oring (AP24738 I think), need to replace? not in the kit (I didn't loose it?)?
3) The hub assembly seems to be different in that the agitator drive seal seems to be built in. The old assembly has the retaining clip, washer and removable agitator drive seal. I would assume that those parts are no longer needed? Please advise. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-04-2008, 02:57 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
1) You can use the Maytag seal grease, part number AP4284075
2) Everything what has to be replaced is included in the kit.
3) The manufacturer has redesigned some parts in the kit.
Before you install the new parts, make sure everything is clean from the rust.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-04-2008, 06:38 PM
Junior Member
Default
OK, Thanks Gene
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge-leaking at float stem? jjoneness Dishwasher Repair 0 12-21-2007 07:39 PM
Drum bearing kit bald2head Dryer Repair 2 12-17-2007 04:17 AM
Leaking tub seal/bearing Mike Luke Washer Repair 1 10-10-2007 03:43 AM
Maytag Washer Bottom of tub leaking at seal David S Washer Repair 4 08-11-2007 12:16 AM
Rear Tub Bearing Justncase Washer Repair 5 08-08-2007 10:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
