Discuss
GE washer won't fill
 in
Washer Repair
I have a GE washer (model WSSH300GWW). It is a front loading model and is about 1 1/2 years
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer won't fill
  #1 (permalink)
Old 07-11-2009, 07:31 PM
knudson knudson is offline
Junior Member
knudson is on a distinguished road
Default GE washer won't fill
Model Number: WSSH300GWW   Brand: GE   Age: 1 - 5 years
I have a GE washer (model WSSH300GWW). It is a front loading model and is about 1 1/2 years old. When I load it with clothes and turn it on, it will not fill with water. Doesn't matter if it set to hot or cold. The drum spins freely and the belt is intact. It is getting plenty of water pressure to both the hot and cold inlets. If I move the dial ahead to the spin cycle, it will spin easily, but no water will go in the tub. When I took the hoses off, I did not see any blockages.
Any ideas?
Bill
Related Models
General Electric WSSR2070V1WW Washer
General Electric WSSR3120W0AA Washer
General Electric WSSR3120W0WW Washer
General Electric WSSR3120W1AA Washer
General Electric WSSR3120W1WW Washer
General Electric WSXH208A0WW Washer
General Electric WSXH208A1WW Washer
General Electric WSXH208F0WW Washer
General Electric WSXH208F1WW Washer
General Electric WSXH208H0WW Washer
General Electric WSXH208T0WB Washer
General Electric WSXH208V0WW Washer
General Electric WSXH208V1WW Washer
Bosch WTA3500 UC/04
Bosch WTA3500 UC/08
Bosch WTA3500 UC/10
Bosch WTA3500 UC/13
Bosch WTA3510 UC/13 (FD 8111-)
Bosch WTA3510 UC/13 (FD 8201-)
Bosch WTL5400 UC/04
Bosch WTL5400 UC/08
Bosch WTL5400 UC/10
Bosch WTL5410 UC/10 (FD 8111-)
Bosch WTL5410 UC/10 (FD 8201-)
White Westinghouse WTR1240AQ0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR1240AS0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR430ES0 White Westinghouse/washer
White Westinghouse WTR430ES1 White Westinghouse/washer
White Westinghouse WTR430FS0 White Westinghouse/washer
General Electric WTRE6260F0GG Washer
General Electric WTRE6260F2GG Washer
General Electric WTSE4210A0WW Washer
Whirlpool WTW5100SQ0 Automatic Washer
Whirlpool WTW5200SQ0 Automatic Washer
Whirlpool WTW5300SQ0 Automatic Washer
Whirlpool WTW5310SQ0 Automatic Washer
Whirlpool WTW5320SQ0 Automatic Washer
Whirlpool WTW5321SQ0 Automatic Washer
Whirlpool WTW5400TQ0 Automatic Washer
Whirlpool WTW5500SQ0 Automatic Washer
Whirlpool WTW5500SQ2 Automatic Washer
Whirlpool WTW5500ST0 Automatic Washer
Whirlpool WTW5500ST2 Automatic Washer
Whirlpool WTW5505SQ0 Automatic Washer
Whirlpool WTW5505SQ1 Automatic Washer
Whirlpool WTW5520SQ0 Automatic Washer
Whirlpool WTW5521SQ0 Automatic Washer
Whirlpool WTW5540SQ0 Automatic Washer
Whirlpool WTW5540ST0 Automatic Washer
Whirlpool WTW5550SQ0 Automatic Washer
Whirlpool WTW5550ST0 Automatic Washer
Whirlpool WTW5560SQ0 Automatic Washer
Whirlpool WTW5590SQ0 Automatic Washer
Whirlpool WTW5590SQ2 Automatic Washer
Whirlpool WTW5590ST0 Automatic Washer
Whirlpool WTW5590ST2 Automatic Washer
Whirlpool WTW5600SQ0 Automatic Washer
Whirlpool WTW5700SW0 Automatic Washer
Whirlpool WTW5790SQ0 Automatic Washer
Whirlpool WTW5790ST0 Automatic Washer
Whirlpool WTW5800SG0 Automatic Washer
Whirlpool WTW5800SW0 Automatic Washer
Whirlpool WTW5810SW0 Automatic Washer
Whirlpool WTW5820SW0 Automatic Washer
Whirlpool WTW5821SW0 Automatic Washer
Whirlpool WTW5830SW0 Automatic Washer
Whirlpool WTW5840SG0 Automatic Washer
Whirlpool WTW5840SW0 Automatic Washer
Whirlpool WTW5850SG0 Automatic Washer
Whirlpool WTW5850SW0 Automatic Washer
Whirlpool WTW5860SG0 Automatic Washer
Whirlpool WTW5860SW0 Automatic Washer
Whirlpool WTW5900SB0 Automatic Washer
Whirlpool WTW5900SW0 Automatic Washer
Whirlpool WTW5900TB0 Automatic Washer
Whirlpool WTW5900TW0 Automatic Washer
Whirlpool WTW6200SW0 Automatic Washer
Whirlpool WTW6200SW1 Automatic Washer
Whirlpool WTW6200SW2 Automatic Washer
Whirlpool WTW6200SW3 Automatic Washer
Whirlpool WTW6300SB0 Automatic Washer
Whirlpool WTW6300SB1 Automatic Washer
Whirlpool WTW6300SB2 Automatic Washer
Whirlpool WTW6300SG0 Automatic Washer
Whirlpool WTW6300SG1 Automatic Washer
Whirlpool WTW6300SG2 Automatic Washer
Whirlpool WTW6300SW0 Automatic Washer
Whirlpool WTW6300SW1 Automatic Washer
Whirlpool WTW6300SW2 Automatic Washer
Whirlpool WTW6400SW0 Automatic Washer
Whirlpool WTW6400SW1 Automatic Washer
Whirlpool WTW6400SW2 Automatic Washer
Whirlpool WTW6400SW3 Automatic Washer
Whirlpool WTW6600SB0 Automatic Washer
Whirlpool WTW6600SB1 Automatic Washer
Whirlpool WTW6600SB2 Automatic Washer
Whirlpool WTW6600SB3 Automatic Washer
Whirlpool WTW6600SG0 Automatic Washer
Whirlpool WTW6600SG1 Automatic Washer
Whirlpool WTW6600SG2 Automatic Washer
Whirlpool WTW6600SG3 Automatic Washer
Whirlpool WTW6600SW0 Automatic Washer
Whirlpool WTW6600SW1 Automatic Washer
Whirlpool WTW6600SW2 Automatic Washer
Whirlpool WTW6600SW3 Automatic Washer
Whirlpool WTW6700TW0 Automatic Washer
Bosch WTZ1170
Bosch WTZ1210
Whirlpool WU0800B
Whirlpool WU0800XX0
Whirlpool WU0800XX1
Maytag WU100 Dishwasher - Undercounter
Maytag WU1000 Dishwasher - Undercounter
Whirlpool WU1000X0
Whirlpool WU1000X1
Whirlpool WU1000X4
Whirlpool WU1000X5
Whirlpool WU1000X6
Whirlpool WU1000X7
Whirlpool WU1000X8
  #2 (permalink)
Old 07-11-2009, 08:00 PM
Junior Member
Default
Here's what I have tested so far. The water inlet valve has 2 solenoids on it with each having a 2 wire connector attached to it. Is there supposed to be voltage coning to these solenoids to open them and allow water to flow through the single outlet hose? When the washer cycle is engaged, there is no voltage coming through any of these wires to the water inlet valve. Does this information help?
  #3 (permalink)
Old 07-12-2009, 11:11 AM
Junior Member
Default
Anyone know how these are supposed to read on a volt meter?
  #4 (permalink)
Old 07-12-2009, 12:00 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Hi Knudson
When the machine is in fill mode there should be 120 volts coming to the solenoids, which will open them.
Sounds like that is not happening with your machine, in which case you probably will have to replace the control assembly. Before doing so you should check the wiring to make certain there is not break or short in the wiring from the assembly to the solenoids.
Hope this helps, good luck with your repair.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not fill Stillshawn Washer Repair 4 10-28-2009 02:40 PM
washer will not fill b63826 Washer Repair 1 10-26-2009 07:14 AM
Washer will not fill lukedog Washer Repair 1 04-14-2009 10:17 AM
Washer will fill only, but will not run. spectra57 Washer Repair 5 08-09-2008 04:00 AM
Washer will not fill johnkh1949 Washer Repair 0 06-16-2008 10:08 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
