my washer won't spin. I believe the belt is bad. How do i get to the belt to replace it. The back of the washer does not have any access plates to open up.
You access this machine from the front. Insert a putty knife or screw driver into the gap between the front and the top at each end which will release clips and enable you to remove the front and give you access to the belt and other components
You can operate the machine with this front cover off to do troubleshooting before you replace the belt or any other component.
Good luck.
