I have a Maytag Neptune washer that will not go into the spin cycle. It will fill and drain. When I put it in service mode (Quick spin test) it tries to spin but binds up. It will then flash the 3E code or the 6E code. I am assuming it is the control board. I would like to know how I can find out if it is the board before I shell out $300 plus dollars for a board.
The code is likely 3E and that means a motor problem, or sensor problem, or wiring problem or who knows what else (that's the problem with this model, the diagnostics are not really diagnosing).
You can try checking the motor, but I think at the end of the day you will be happier replacing the machine.
