Fabric Softener not dispensing
Washer Repair
This is a front loader that works in all modes except fabric softener. The dispenser appears to be controlled by
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Fabric Softener not dispensing
  #1 (permalink)
Old 07-11-2009, 10:43 AM
Junior Member
erkflys is on a distinguished road
Default Fabric Softener not dispensing
Model Number: FWT449GFS1   Brand: Frigidaire   Age: More than 10 years
This is a front loader that works in all modes except fabric softener. The dispenser appears to be controlled by an arm that is activated by the timer cam. At the center pivot of the arm there is an adjustment tab that goes from +3 to 3. When moving the tab, the pivot point adjusts slightly but I see no effect at the dispenser. If I understand the process the incoming water floods the dispenser box and the liquid softener raises to the top of an overflow tube and then into the washing machine. The bleach dispenses in the same way and works correctly. Removing the dispenser box looks to be a major undertaking that requires the removal of heavy springs connected to the washer tub. Please help.
Related Models
Frigidaire FWT449GFS1 Frg(v0) / Front Load Washer
Frigidaire FWT449GFS2 Frg(v0) / Free Standing Washer
Frigidaire FWT645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWT645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS0 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWT648GHS0 Frg/washer
Frigidaire FWT867GHQ0 Frg/washer
Frigidaire FWT867GHS0 Frg/washer
Frigidaire FWTB59RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB69RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB8200DS0 Frigidaire/washer
Frigidaire FWTBB30DS0 Frigidaire/washer
Frigidaire FWTR425RHS0 Frg(v0) / Front Load Washer
Frigidaire FWTR445RFS0 Frg(v0) / Washer
Frigidaire FWTR445RFS1 Frg/washer
Frigidaire FWTR445RFS2 Frg(v0) / Front Load Washer
Frigidaire FWTR549GG Frg(v0) / Free Standing Washer
Frigidaire FWTR549GGS0 Frg/washer
Frigidaire FWTR549GS0
Frigidaire FWTR645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWTR645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWTR647GHS0 Frg(v0) / Washer
Frigidaire FWTR647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWTR865RHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR865RHS0 Frg(v2) / Front Load Washer
Frigidaire FWTR867GHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR867GHS0 Frg(v2) / Front Load Washer
Frigidaire FWX133RBS0 Frg(v2) / 27 " Washer
Frigidaire FWX133RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX133RBS2 Frg(v1) / Washer
Frigidaire FWX133RBS3 Frg(v1) / Washer
Frigidaire FWX221AS0 Washer - Frigidaire
Frigidaire FWX221AS1 Washer - Frigidaire
Frigidaire FWX221AS2 Frigidaire/washer
Frigidaire FWX223LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX223LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX223LBS2 Frg(v2) / Washer
Frigidaire FWX223LBS3 Frg(v2) / Washer
Frigidaire FWX223LBS4 Frg(v0) / Washer
Frigidaire FWX223LBS5 Frg(v0) / Washer
Frigidaire FWX223LBS6 Frg/washer
Frigidaire FWX223LBS7 Frg(v0) / Free Standing Washer
Frigidaire FWX223LBS8 Frg/washer
Frigidaire FWX225RHS0 Frg(v0) / Washer
Frigidaire FWX225RHS1 Frg/washer
Frigidaire FWX233MRES0 Frg(v0) / Refrigerator
Frigidaire FWX233NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX233NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX233NBS2 Frg(v1) / Washer
Frigidaire FWX233NBS3 Frg(v0) / Washer
Frigidaire FWX233RES0 Frg(v0) / Washer
Frigidaire FWX233RES1 Frg(v0) / Washer
Frigidaire FWX233RES2 Frg(v0) / Washer
Frigidaire FWX233RES3 Frg(v0) / Washer
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
  #2 (permalink)
Old 07-12-2009, 06:58 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Hi Erkflys
I think your problem is either in the solenoid that control water flow into the bleach dispenser cavity or the timer. The timer should send current to the solenoid at the time to release the fabric softener, which allows water to enter the dispenser and dispense softener exactly as you have stated.
See if you can measure voltage to the solenoid at the time softener must be dispensed. If there is current, the solenoid is likely the problem, if there is not 120 volts, then the timer is likely the problem.
Good luck
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fabric Softener Dispenser Pam Denny Washer Repair 3 01-16-2010 06:43 PM
Not dispensing fabric softener erkflys Washer Repair 0 07-10-2009 10:54 AM
Fabric Softener Dispenser Jerry Price Washer Repair 1 06-23-2009 03:44 PM
grease in fabric softener cup footloose Washer Repair 2 06-23-2008 05:50 PM
loose fabric softener dispenser deanber Washer Repair 2 02-23-2008 09:38 AM
