| » Washer motor thermal switch opening |
Model Number: MVWC6ESWW1 Brand: Maytag Age: 1 - 5 years
Washer fills with water than startes to agitate. After a few seconds motor gets hot and stops (thermal switch on motor opens) when thermal switch cools down motor runs again for a few more seconds then repeats over and over.
I would disassemble the washer and remove the motor, but leave the wire harness connected to the motor so I could run the motor by itself.
If it still trips the thermal overload then I would replace the motor. Other wise if the motor runs fine then something that the motor drives is turning hard or binding.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| tripping thermal protection switch | ldperry | Oven Repair (including Ranges and Cooktops) | 0 | 10-02-2011 05:50 PM |
| GE Oven - Which limit switch is one time thermal switch(two are close on diagram) | personalt | Oven Repair (including Ranges and Cooktops) | 2 | 04-26-2011 04:57 AM |
| Washer motor switch re-assemble | WindEng | Washer Repair | 2 | 10-22-2009 06:42 AM |
| maytag washer motor switch | happ racer | Washer Repair | 1 | 10-07-2009 06:20 AM |
| thermal fuse or switch | kpwhitte | Oven Repair (including Ranges and Cooktops) | 3 | 10-07-2009 04:28 AM |
