Discuss
washer will not spin
 in
Washer Repair
Just got the washer from a friend.....the washer will not spin, it goes thru all the cycles. But, when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer will not spin
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-03-2008, 12:12 PM
sharp sharp is offline
Junior Member
sharp is on a distinguished road
Question washer will not spin
Model Number: RAL5144ALO   Brand: Roper   Age: 5 - 10 years
Just got the washer from a friend.....the washer will not spin, it goes thru all the cycles. But, when it starts to spin it makes a loud "clanging noise"...and other times, it does not make the noise, but will not spen..we would appricate some ideas..thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 12:25 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does it drain?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-03-2008, 12:36 PM
Junior Member
Default
yes,it drains all, except what is in the clothes.
  #4 (permalink)
Old 01-03-2008, 01:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad motor drive coupling (#13 on the motor and pump break down diagram).
- The part number for the motor drive coupling is AP3963893
- Here are the break down diagrams for the Roper washer Model RAL5144AL0
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin chevy2 Washer Repair 6 03-10-2008 12:47 PM
Washer will not spin cncndreamz Washer Repair 1 12-21-2007 02:04 PM
Washer won't spin madmanracing11 Washer Repair 3 11-21-2007 07:00 AM
Washer will not spin on spin cycle bellboy Washer Repair 0 11-11-2007 08:16 AM
washer won't spin Craig Washer Repair 1 09-30-2007 08:33 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
