The washer doesn't drain on the last spin cycle. The clothes remain wet sitting in a small puddle of water and there is a musty smell. Can this be solved with new parts? Thank you
If you have a laundry sink, put the drain hose into and see if it drains after the wash cycle. If not, there may be an obstruction in the drain hoses or the pump.
