Discuss
Washing Machine
 in
Washer Repair
My Roper washing machine is leaking water continually. It is like a drip. Could this be one of the water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing Machine
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-03-2008, 10:30 AM
Bob Mutersbaugh Bob Mutersbaugh is offline
Junior Member
Bob Mutersbaugh is on a distinguished road
Default Washing Machine
Brand: Roper   Age: 5 - 10 years
My Roper washing machine is leaking water continually. It is like a drip. Could this be one of the water connections to the water pump?
How do I remove the cover? I cannot figure out how to get control panel off.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 04:01 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
is the leak coming from front centre.if so it may be pump
__________________
  #3 (permalink)
Old 03-04-2008, 07:40 AM
Thesodfather Thesodfather is offline
Junior Member
Thesodfather is on a distinguished road
Default
I also have a Roper washing machine and need to know how to take the cover off. How do you get to the pump to replace it?
My model # is RAS7233Q0
Thanks in advance
  #4 (permalink)
Old 03-04-2008, 08:01 AM
Senior Expert
APP Volunteer
Default
behind control panel on either side there are 2 screws .once they are removed, you pull the control panel forward +up+lean back. now you will see 2 brass coulered long clips on either side.slip a screwdriver under clip and pull forward +up. remove. there is a small wiring harness towards right attatached to cabinet, pull apart , now lift up on lid ,put hand on cabinet under lid and pull forward on cabinet ,put aside. at bottom you will see plastic pump wth 2 hoses held down by 2 clips ,remove with slot screwdriver.pull pump off, hopefully pump is not rusted on. if so you might have to cut pump off . remove hoses from pump. good luck
__________________
  #5 (permalink)
Old 03-04-2008, 11:45 AM
Junior Member
Default
Thanks That is just what i needed.
James
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing machine Novice Washer Repair 2 10-08-2007 11:22 AM
Washing Machine Gtaeza Dishwasher Repair 0 09-27-2007 08:19 AM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 02:42 AM
Washing Machine jherriff Washer Repair 1 09-10-2007 11:03 AM
GE washing machine paul Washer Repair 2 07-19-2007 07:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
