| » Frigidaire front load washer will not spin |
Quote:
Frigidaire Gallery Series I have read through all the posts and got pretty far, considering I don’t know how to fix much. I ran the diagnostics and got an error 47. I pulled the lock assembly out and tested for resistance and got an 1179. I am not sure if that means it is fine or if it needs to be replaced. I also tested the control panel and got the following readings: J2=.5 J3=.455 J7=44.3 J14=273.7 J1=54.7 J4=I am not sure if this was reading correct or not. It would not give me a reading unless I put both black and red on the same prong. Then it only gave me a .2. I am not sure if it was saying OL since it didn’t appear to be reading anything. J6=I couldn’t pull this out to get a reading so I just left it alone. At this point, I don’t know what these numbers are suggesting. Please help me with getting the right part(s). |
Hello. We have a frigidaire front loader. It's about ten years old.
It stop spinning. It will fill and drain but no agitate or spin we called sears and the repairman said the motor was bad. Quoted me 390$ to fix but said it wasn't worth fixing and to buy a new machine. I ordered a motor online and installed it tonite. Still no spin??? so obviously the repairman was wrong i am not electrically inclined but it must be either the control board to the left of the motor or the door switch the motor control board doesn't look like its burned or anything if I turn the machine on in the spin cycle, the light for “spin” comes on. If I push the knob in to pause, I can immediately open the door. It's not locked. Does that mean that my lock switch is bad? I do not have a voltage meter so I don't know how to check it by ohms thank you |
What is the complete model number of the washer?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
These results are enough to say that the problem is a bad door lock assembly. No more tests required. - The door lock assembly Part number: 131763202 Although, it's probably too late to help you, I'm posting the answer anyway, so that it may help other people with a similar problem. Gene.
__________________
| Display Modes | |
| frigidaire front load washer will not spin only tumbles | FILTTY | Washer Repair | 1 | 02-14-2010 06:53 AM |
| frigidaire front load washer will not go into final spin | cubbie23 | Washer Repair | 2 | 02-12-2010 12:40 PM |
| Front load Frigidaire won't spin at all | Gangster | Washer Repair | 2 | 12-13-2008 07:33 AM |
| Frigidaire front load washer won't spin | jociadam | Washer Repair | 1 | 07-03-2008 06:52 AM |
| Frigidaire Front Load Washer Won't Spin | bbemis | Washer Repair | 2 | 11-28-2007 07:46 AM |
