Discuss
interrupted cycles
 in
Washer Repair
Got a whirlpool ultimate care ll. I've replaced the lid switch and the timer control. The reason I did that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » interrupted cycles
  #1 (permalink)
Old 01-09-2012, 02:43 PM
Junior Member
tkunz14 is on a distinguished road
Default interrupted cycles
Model Number: lsb6200kqo   Brand: Whirlpool   Age: More than 10 years
Got a whirlpool ultimate care ll. I've replaced the lid switch and the timer control. The reason I did that was after filling and running half way through the wash cycle it stopped. Manually advancing the timer didn't work. After replacing the two parts we can get it to fill, spin(will continue to fill during), and drain. but it won't agitate or spin without filling. Any idea what parts might need to be looked at?
Ads By Google
Related Models
Whirlpool LSB6200PQ0 Automatic Washer
Whirlpool LSB6200PQ1 Automatic Washer
Whirlpool LSB6200PQ2 Automatic Washer
Whirlpool LSB6300LQ0
Whirlpool LSB6300LW0
Whirlpool LSB6300LW1 Automatic Washer
Whirlpool LSB6300LW2 Automatic Washer
Whirlpool LSB6300LW3 Automatic Washer
Whirlpool LSB6300PW0 Automatic Washer
Whirlpool LSB6300PW1 Automatic Washer
Whirlpool LSB6300PW3 Automatic Washer
Whirlpool LSB6300PW4 Automatic Washer
Whirlpool LSB6400KQ0
Whirlpool LSB6400KQ1
Whirlpool LSB6400LW0
Whirlpool LSB6400LW1 Automatic Washer
Whirlpool LSB6500PW0 Automatic Washer
Whirlpool LSB6500PW1 Automatic Washer
Whirlpool LSB6500PW2 Automatic Washer
Whirlpool LSB6500PW3 Automatic Washer
Whirlpool LSB6500PW4 Automatic Washer
Whirlpool LSC5000PQ0 Automatic Washer
Whirlpool LSC5000PQ1 Automatic Washer
Whirlpool LSC5000PQ2 Automatic Washer
Whirlpool LSC6244AN0
Whirlpool LSC6244AQ0
Whirlpool LSC6244AW0
Whirlpool LSC6244AZ0
Whirlpool LSC6244BN0
Whirlpool LSC6244BQ0
Whirlpool LSC6244BW0
Whirlpool LSC6244BZ0
Whirlpool LSC8244BG0
Whirlpool LSC8244BG1
Whirlpool LSC8244BN0
Whirlpool LSC8244BN1
Whirlpool LSC8244BQ0
Whirlpool LSC8244BQ1
Whirlpool LSC8244BW0
Whirlpool LSC8244BW1
Whirlpool LSC8244BZ0
Whirlpool LSC8244BZ1
Whirlpool LSC8244DQ0
Whirlpool LSC8244DZ0
Whirlpool LSC8244EQ0
Whirlpool LSC8244EQ1
Whirlpool LSC8244EZ0
Whirlpool LSC8244EZ1
Whirlpool LSC8245AN0
Whirlpool LSC8245AQ0
Whirlpool LSC8245AW0
Whirlpool LSC8245BN0
Whirlpool LSC8245BW0
Whirlpool LSC9000PW0 Automatic Washer
Whirlpool LSC9000PW1 Automatic Washer
Whirlpool LSC9000PW2 Automatic Washer
Whirlpool LSC9245BN0
Whirlpool LSC9245BN1
Whirlpool LSC9245BQ0
Whirlpool LSC9245BQ1
Whirlpool LSC9245BW0
Whirlpool LSC9245BW1
Whirlpool LSC9245BZ0
Whirlpool LSC9245BZ1
Whirlpool LSC9355AG0
Whirlpool LSC9355AN0
Whirlpool LSC9355AW0
Whirlpool LSC9355BN0
Whirlpool LSC9355BN1
Whirlpool LSC9355BQ0
Whirlpool LSC9355BQ1
Whirlpool LSC9355BW0
Whirlpool LSC9355BW1
Whirlpool LSC9355BZ0
Whirlpool LSC9355BZ1
Whirlpool LSC9355DQ0
Whirlpool LSC9355DZ0
Whirlpool LSC9355EQ0
Whirlpool LSC9355EQ1
Whirlpool LSC9355EZ0
Whirlpool LSC9355EZ1
Admiral LSD2615HEB Ref - SXS/I&W
Admiral LSD2615HEW Ref - SXS/I&W
Admiral LSD2615HEZ Ref - SXS/I&W
Maytag LSE1000 Stacked Laundry - Ele
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W Stacked Laundry - Ele
Jenn-Air LSE2700W-8 Stacked Laundry - Ele
Jenn-Air LSE2700W-C Stacked Laundry - Ele
Jenn-Air LSE2704W Stacked Laundry - Ele
Jenn-Air LSE2704W-8 Stacked Laundry - Ele
Maytag LSE7800 Stacked Laundry - Ele
Maytag LSE7800ACE Stacked Laundry - Ele
Maytag LSE7800ACL Stacked Laundry - Ele
Maytag LSE7800ACW Stacked Laundry - Ele
Maytag LSE7800ADE Stacked Laundry - Ele
Maytag LSE7800ADL Stacked Laundry - Ele
Maytag LSE7800ADW Stacked Laundry - Ele
Maytag LSE7800AEE Stacked Laundry - Ele
Maytag LSE7800AEL Stacked Laundry - Ele
Maytag LSE7800AEW Stacked Laundry - Ele
International LSE7800AGE Stacked Laundry - Ele
International LSE7800AGL Stacked Laundry - Ele
Maytag LSE7804ACE Stacked Laundry - Ele
Maytag LSE7804ACL Stacked Laundry - Ele
Maytag LSE7804ACM Stacked Laundry - Ele
Maytag LSE7804ADE Stacked Laundry - Ele
Maytag LSE7804ADL Stacked Laundry - Ele
Maytag LSE7804ADM Stacked Laundry - Ele
Maytag LSE7804AEE Stacked Laundry - Ele
International LSE7804AGE Stacked Laundry - Ele
International LSE7804AGL Stacked Laundry - Ele
International LSE7804AGM Stacked Laundry - Ele
Maytag LSE7806ACE Stacked Laundry - Ele
Maytag LSE7806ACM Stacked Laundry - Ele
Maytag LSE7806ACQ Stacked Laundry - Ele
Maytag LSE7806ADE Stacked Laundry - Ele
Maytag LSE7806ADM Stacked Laundry - Ele
Maytag LSE7806ADQ Stacked Laundry - Ele
Maytag LSE7806AEE Stacked Laundry - Ele
  #2 (permalink)
Old 01-10-2012, 06:09 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well what you did should have fixed it, so I am going to suggest you change out the water level switch. That shouldn't be the problem but that is the only thing I can think of other than the timer that would cause your problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
spins 3 cycles one way, 3 cycles the other way, then will not spin after that huntly Washer Repair 2 09-26-2011 04:10 AM
Cycle interrupted by bad door latch Barrister Dishwasher Repair 5 08-13-2010 06:29 AM
GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points nickf829 Washer Repair 1 12-20-2009 04:43 PM
