Discuss
Motor won't run
 in
Washer Repair
I have a clothes washer that only fills with water when you start the cycle, but the motor will not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Motor won't run
  #1 (permalink)
Old 01-09-2012, 01:55 PM
Junior Member
Tnehmz is on a distinguished road
Unhappy Motor won't run
Model Number: LW6153WM   Brand: Amana   Age: More than 10 years
I have a clothes washer that only fills with water when you start the cycle, but the motor will not run. I can hear power inside the machine that sounds like a hum, like contactors are stuck. The motor turns freely, as does the water pump attached to it. I have heard this with A/C units, and it is usually the motor start capacitor. In this case, there isn't one. What could be preventing the motor from starting and the machine from running?
Ads By Google
Related Models
Amana LW6153WM WASHER-TOP LOADING
Amana LW6163LM WASHER-TOP LOADING
Amana LW6163WM WASHER-TOP LOADING
Amana LW6501W2 WASHER-TOP LOADING
Amana LW6501W2B WASHER-TOP LOADING
Amana LW6601W2 WASHER-TOP LOADING
Amana LW6661W2 WASHER-TOP LOADING
Amana LW7503L2 WASHER-TOP LOADING
Amana LW7503W2 WASHER-TOP LOADING
Amana LW7563W2 WASHER-TOP LOADING
 LW8000ER Air Conditioner
Amana LW8201L2 WASHER-TOP LOADING
Amana LW8201W2 WASHER-TOP LOADING
Amana LW8203L2 WASHER-TOP LOADING
Amana LW8203W WASHER-TOP LOADING
Amana LW8203W2 WASHER-TOP LOADING
Amana LW8203W2B WASHER-TOP LOADING
Amana LW8252L2 WASHER-TOP LOADING
Amana LW8252W2 WASHER-TOP LOADING
Amana LW8253W WASHER-TOP LOADING
Amana LW8263W2 WASHER-TOP LOADING
Amana LW8303L2 WASHER-TOP LOADING
Amana LW8303W2 WASHER-TOP LOADING
Amana LW8312L2 WASHER-TOP LOADING
Amana LW8312W2 WASHER-TOP LOADING
Amana LW8363L2 WASHER-TOP LOADING
Amana LW8363W2 WASHER-TOP LOADING
Amana LW8403W WASHER-TOP LOADING
Amana LW8413L2 WASHER-TOP LOADING
Amana LW8413W2 WASHER-TOP LOADING
Amana LW8413W2B WASHER-TOP LOADING
Amana LW8463L2 WASHER-TOP LOADING
Amana LW8463W2 WASHER-TOP LOADING
Amana LW9003 WASHER-TOP LOADING
Amana LW9103 WASHER-TOP LOADING
Amana LW9103W WASHER-TOP LOADING
Amana LW9203L2 WASHER-TOP LOADING
Amana LW9203W WASHER-TOP LOADING
Amana LW9203W2 WASHER-TOP LOADING
Amana LWA05AW WASHER-TOP LOADING
Amana LWA10AW WASHER-TOP LOADING
Amana LWA18AW WASHER-TOP LOADING
Amana LWA20AW WASHER-TOP LOADING
Amana LWA30AL WASHER-TOP LOADING
Amana LWA30AW WASHER-TOP LOADING
Amana LWA30BL WASHER-TOP LOADING
Amana LWA30BW WASHER-TOP LOADING
Amana LWA40AL WASHER-TOP LOADING
Amana LWA40AL2 WASHER-TOP LOADING
Amana LWA40AW WASHER-TOP LOADING
Amana LWA40AW2 WASHER-TOP LOADING
Amana LWA50AL WASHER-TOP LOADING
Amana LWA50AW WASHER-TOP LOADING
Amana LWA60AL WASHER-TOP LOADING
Amana LWA60AW WASHER-TOP LOADING
Amana LWA65AL WASHER-TOP LOADING
Amana LWA65AW WASHER-TOP LOADING
Amana LWA80AL WASHER-TOP LOADING
Amana LWA80AW WASHER-TOP LOADING
Amana LWA90AL WASHER-TOP LOADING
Amana LWA90AW WASHER-TOP LOADING
Amana LWC05AW WASHER-TOP LOADING
Amana LWC07AW WASHER-TOP LOADING
Amana LWC18AW WASHER-TOP LOADING
Amana LWC30AW WASHER-TOP LOADING
Amana LWC40AW WASHER-TOP LOADING
Amana LWC50AW WASHER-TOP LOADING
Amana LWC75AW WASHER-TOP LOADING
Amana LWC80AW WASHER-TOP LOADING
Amana LWC90AW WASHER-TOP LOADING
Amana LWD250 WASHER-TOP LOADING
Amana LWD27AW WASHER-TOP LOADING
Amana LWD27BW WASHER-TOP LOADING
 LWD3081ST Electric Range
Amana LWD352 WASHER-TOP LOADING
Amana LWD352L WASHER-TOP LOADING
Amana LWD352W WASHER-TOP LOADING
  #2 (permalink)
Old 01-10-2012, 06:00 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
These motors have start windings in place of a capacitor, so the start windings can be a problem and not show up as you turn the motor.
If you are comfortable doing so, see if you can manually turn the belt when the motor is trying to start, but BE VERY CAREFUL!!
If it starts, the motor is bad.
The other place to check is the motor switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Error Message , motor not rotating , I replaced motor with clutch with a new one Danson73 Washer Repair 1 08-31-2011 06:21 PM
intermittent power to motor/motor control board rsssalty Washer Repair 4 08-25-2011 10:41 PM
Noisy Whirlpool Dishwasher: Replace just motor or whole pump&motor mdion Dishwasher Repair 7 02-28-2011 01:31 PM
can I replace a magnetic evaporator fan motor with an electric motor ainexy Refrigerator & Freezer Repair 5 02-21-2011 01:22 PM
Whirlpool dishwasher parts - replace motor or motor AND pump? dishwasher hums Dishwasher Repair 4 01-04-2011 04:57 AM
