Discuss
Washer doesn't go into spin cycle
 in
Washer Repair
Our Kenmore Oasis Elite washer has problems. We have to unplug and let it sit for 30 minutes for it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer doesn't go into spin cycle
  #1 (permalink)
Old 07-09-2009, 06:49 PM
Keithgx1 Keithgx1 is offline
Junior Member
Keithgx1 is on a distinguished road
Default Washer doesn't go into spin cycle
Model Number: 110.27062602   Brand: Kenmore   Age: 1 - 5 years
Our Kenmore Oasis Elite washer has problems. We have to unplug and let it sit for 30 minutes for it to reset and then we can start a load of clothes. The washer will progress through the wash stage until it goes to the first spin cycle. The motor then continues to run but won't spin or rinse. If we unplug it again, let it set idle for another 30 minutes, then manually enter the spin cycle, it might work.
I know the control panels on similar models have been recalled. Is that what we need to replace?
Related Models
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Kenmore 110.5807961  KENMORE GAS DRYER
Kenmore 110.5808000  KENMORE ELECTRIC DRYER
Kenmore 110.5808010  KENMORE ELECTRIC DRYER
Kenmore 110.5808100  KENMORE ELECTRIC DRYER
Kenmore 110.5808300  KENMORE ELECTRIC DRYER
Kenmore 110.5808500  KENMORE ELECTRIC DRYER
Kenmore 110.5808700  KENMORE ELECTRIC DRYER
Kenmore 110.5808800  KENMORE ELECTRIC DRYER
Kenmore 110.5808810  KENMORE ELECTRIC DRYER
Kenmore 110.5808850  KENMORE ELECTRIC DRYER
Kenmore 110.5808860  KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 07-11-2009, 07:54 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Hi Keith
I have only worked on this model a few times, and never with your problem. The motor turning but the machine not spinning is somewhat of a mystery, but it implies a problem in the drive system.
Here is a service manual, which is helpful in taking you through a diagnostic testing system, but not for much else.
http://repair2000.com/Library/whirlp...yst_washer.pdf
Good luck, sorry I could not give more info.
__________________
  #3 (permalink)
Old 09-05-2009, 08:15 PM
RangerRickT RangerRickT is offline
Junior Member
RangerRickT is on a distinguished road
Default
Today, we too got the Ld fault code with an Oasis (110.27082602) washer of similar vintage. I initiated the automated diagnostics which displayed two saved/logged fault codes: F51 and F32. The automated diagnostics did not show a failure, and the technician's troubleshooting guide had numerous manual initiated tests to try - though none exactly matched the conditions of Ld code with empty washer tub. I tried all the tests without finding an error; with the last test, I eventually reset the pressure sensor zero reading. This action seemed logical as the washer drain pump would continue to run after emptying the tub; it didn't seem to "know" that it was empty and move onto the spin cycle. This reset worked for now - we've done 3-4 loads with no problem. I have my fingers crossed that I don't have to replace the control board!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 4 08-19-2009 07:32 PM
Amana washer will not spin on last spin cycle karenmf Washer Repair 1 06-07-2009 09:05 AM
Washer will not go through rinse or spin cycle on regular cycle dhilde7165 Washer Repair 0 02-14-2009 05:10 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 08:44 AM
washer won't spin in final spin cycle amie48 Washer Repair 0 01-12-2008 01:59 PM
