Anyone know how to fix Whirlpool WTW5200Sq top loading wash machine 4 years old. It shakes while spinning enuf to move washer around on floor. I took it appart, but everything looks good. Thank you
The problem with these is a lot of times you just cannot see the problem. Start by changing out the springs and pads, which are inexpensive.
If that fails you may have a hairline fracture, and will have to change out some of the support structure like the tub support.
Thank you. All plastic pads looks good without any wearings. I'll try to replace 3 springs first.
Good, let us know how it goes
