Pressure switch has a 'moveable plate' that looks like the profile (top) of a B-1 bomber. What are the different setting do? I've tried to upload a photo for your inspection. John jkmvenice attached the following image(s):
Are those different settings for water level or are those different settings so that this particular pressure switch can be used in a variety of different tub volumes?
I've often wondered if water level is adjustable?
Can not adjust water volume, adjusts water level.
