Discuss
Maytag Stack unit- dryer must be on for washer to run
 in
Washer Repair
The weirdest thing....this washer has been known to blow some fuses in the past so I've always suspected some type
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Stack unit- dryer must be on for washer to run
  #1 (permalink)
Old 07-08-2009, 05:30 PM
Junior Member
Hamilton9272 is on a distinguished road
Default Maytag Stack unit- dryer must be on for washer to run
Brand: Maytag   Age: 1 - 5 years
The weirdest thing....this washer has been known to blow some fuses in the past so I've always suspected some type of electrical problem, but this one is really strange.
The dryer must be on and running for the washer to do anything. The dryer even needs to be running with hot air for the washer to start (if it's just "fluff air" in the permanent press cycle, that won't make the washer start.
Suggestions?
harry
Ads By Google
  #2 (permalink)
Old 07-09-2009, 05:21 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well, that is weird, and new.
You are going to have to open it up and check the wiring for a short of some type. I would start with the wiring going into the heater and try to trace it back. Given you description at some point that wiring must be interacting with the washer wiring.
Good luck, everyone will be curious as to what you find out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer dryer stack brnthrt@hotmail.com Dryer Repair 2 05-03-2011 04:13 PM
Maytag SE1000 stack dryer motor removal Lynn Finch Dryer Repair 0 12-23-2009 01:06 PM
maytag stack washer dryer tdbates6 Washer Repair 1 12-02-2009 12:38 PM
Maytag Stack unit won't fill with water Hamilton9272 Washer Repair 0 02-22-2009 07:15 AM
stack washer/dryer martint Dryer Repair 2 02-03-2009 09:47 PM
