Discuss
Washer Won't Agitate or Spin
 in
Washer Repair
Washer is 3 years old, recently had an issue with water under the washer, so I pulled it out, checked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Won't Agitate or Spin
  #1 (permalink)
Old 01-05-2012, 06:01 PM
Junior Member
jeffnett1009 is on a distinguished road
Default Washer Won't Agitate or Spin
Model Number: WJRE5500G1WW   Brand: GE   Age: 1 - 5 years
Washer is 3 years old, recently had an issue with water under the washer, so I pulled it out, checked hose connections, cleaned out drain pipe, and removed the front panel and detached the top (except for the lid switch).
I determined the leak to just have been from splashing through cycles with too much water for too little clothes, as water was coming out of the flood drain pipe during agitation (no leaking when filled for super load).
Relieved, I put the top panel back on and did another test -- now it does everything it's supposed to except it no longer will agitate or spin. It will go through a whole cycle (fill & drain through each part of the cycle), but it won't move.
I found suggestions to try unplugging to reset the washer, I checked the lid switch which was pulled out slightly from my removing/reattaching the top and I read that if the lid switch was a problem, it wouldn't drain properly.
The green light blinks when it should be agitating during the wash cycle -- 4 brief blinks in a row, then about 6 or 7 seconds off, and this repeats.
I'm not real inclined with this stuff, but it seems like it must be simple since it was just working earlier today. Is it possible I accidentally cut or detached a wire from the control panel when re-attaching the top? I did hear a kind of popping noise when putting it back on, but figured it was the lid switch.
--- EDIT: Now that I look closer at the lid switch piece that has wires running to the motor, it looks like the small silver wire may have snapped apart in the middle (I'm not sure if this was one piece to begin with). Could this be the root cause for the motor never agitating/spinning? How do I bypass the lid switch to test this?
--- EDIT 2: Pretty sure it's the lid switch -- I didn't realize there is actually a tiny glass tube that's supposed to be around the silver wire in the lid switch assembly, and this tube is busted with the wire actually sticking out. Any quick fix remedy for this, or will I have to replace the whole lid switch assembly?
Any help/ideas appreciated!
Thanks,
Jeff
Ads By Google
Related Models
General Electric WJRR4170E0CC Washer
General Electric WJRR4170E0WW Washer
General Electric WJRR4170E1CC Washer
General Electric WJRR4170E1WW Washer
General Electric WJRR4170E3CC Washer
General Electric WJRR4170E3WW Washer
General Electric WJRR4170E4CC Washer
General Electric WJRR4170E4WW Washer
General Electric WJRR4170E5CC Washer
General Electric WJRR4170E5WW Washer
General Electric WJRR4170E6CC Washer
General Electric WJRR4170E6WW Washer
General Electric WJRR4170G0WW Washer
General Electric WJSE3110A0AA Washer
General Electric WJSE3110A0CC Washer
General Electric WJSE3110A0WW Washer
General Electric WJSE3110A2CC Washer
General Electric WJSE3110A2WW Washer
General Electric WJSE4150B0CC Washer
General Electric WJSE4150B0WW Washer
General Electric WJSE4150B1CC Washer
General Electric WJSE4150B1WW Washer
General Electric WJSE4150B2CC Washer
General Electric WJSE4150B2WW Washer
General Electric WJSE4150B3CC Washer
General Electric WJSE4150B3WW Washer
General Electric WJSR1070A1AA Washer
General Electric WJSR1070A1CC Washer
General Electric WJSR1070A1WW Washer
General Electric WJSR1070A2AA Washer
General Electric WJSR1070A2WW Washer
General Electric WJSR2070B0CC Washer
General Electric WJSR2070B0WW Washer
General Electric WJSR2070B2CC Washer
General Electric WJSR2070B2WW Washer
General Electric WJSR2070B3CC Washer
General Electric WJSR2070B3WW Washer
General Electric WJSR2070B4CC Washer
General Electric WJSR2070B4WW Washer
General Electric WJSR2070D0WW Washer
General Electric WJSR2070D1WW Washer
General Electric WJSR2070D2WW Washer
General Electric WJSR2070D3WW Washer
General Electric WJSR2070D5WW Washer
General Electric WJSR2070D6WW Washer
General Electric WJSR2080T2AA Washer
General Electric WJSR2080T2WB Washer
General Electric WJSR2080T2WW Washer
General Electric WJSR2080T3AA Washer
General Electric WJSR2080T3WB Washer
General Electric WJSR2080T3WW Washer
General Electric WJSR2080T5AA Washer
General Electric WJSR2080T5WB Washer
General Electric WJSR2080T5WW Washer
General Electric WJSR2080T6AA Washer
General Electric WJSR2080T6WB Washer
General Electric WJSR2080T6WW Washer
General Electric WJSR2080T8AA Washer
General Electric WJSR2080T8WB Washer
General Electric WJSR2080T8WW Washer
General Electric WJSR2080TAAA Washer
General Electric WJSR2080TAWB Washer
General Electric WJSR2080TAWW Washer
General Electric WJSR2080V1AA Washer
General Electric WJSR2080V1WW Washer
General Electric WJSR2080V2AA Washer
General Electric WJSR2080V2WW Washer
General Electric WJSR2080V3AA Washer
General Electric WJSR2080V3WW Washer
General Electric WJSR4160D0CC Washer
General Electric WJSR4160D0WW Washer
General Electric WJSR4160D2CC Washer
General Electric WJSR4160D2WW Washer
General Electric WJSR4160D5CC Washer
General Electric WJSR4160D5WW Washer
General Electric WJSR4160D6CC Washer
General Electric WJSR4160D6WW Washer
General Electric WJSR4160DACC Washer
General Electric WJSR4160DAWW Washer
General Electric WJSR4160DCCC Washer
General Electric WJSR4160DCWW Washer
General Electric WJSR4160G0WW Washer
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" Electric Range Ceran Cooktop
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
General Electric WKSE6280B1WW Washer
General Electric WKSE6280B2WW Washer
General Electric WKSE6280B3WW Washer
General Electric WKSR2100T2AA Washer
General Electric WKSR2100T2WW Washer
General Electric WKSR2100T3AA Washer
General Electric WKSR2100T3WW Washer
General Electric WKSR2100T5AA Washer
General Electric WKSR2100T5WW Washer
General Electric WKSR2100T6AA Washer
General Electric WKSR2100T6WW Washer
General Electric WKSR2100T8AA Washer
General Electric WKSR2100T8WW Washer
General Electric WKSR2100T9AA Washer
General Electric WKSR2100T9WW Washer
General Electric WKSR2100TAAA Washer
General Electric WKSR2100TAWW Washer
  #2 (permalink)
Old 01-05-2012, 09:46 PM
Junior Member
Default
Well, I resolved my own issue -- knowing the lid switch was busted, I cut it out by snipping both wires leading to it, then cut some of the casing off of both wires, twisted them together, and wrapped in electrical tape. Runs fine now with the magnetic lid switch bypassed until I can get and install a replacement lid switch assembly.
My problem was removing and replacing the top cover without first removing the lid switch assembly. It ended up pulling the hard gel casing out of the assembly and eventually busted the inside of it (the glass in the lid switch assembly breaking was probably the loud popping noise I heard).
Hope this might help anyone else with the same problem!
  #3 (permalink)
Old 01-06-2012, 12:28 AM
Junior Member
Default
Scratch that... it worked once (maybe 1 1/2 times). Now it won't agitate or spin again. I found the second load I did hadn't spun and the clothes were still soaked (the 1st load had spun fine). Tried running just a drain and spin and then a quick rinse, and neither worked.
Now I'm at a loss about what to try... Please help!!!
  #4 (permalink)
Old 01-06-2012, 06:41 AM
Junior Member
Default
I found what the 4 flash code means:
HydroWave GE Washer Repair Guide
4 flashes - Mode shifter circuit failed. If this error code comes up the motor will still operate but if the mode shifter circuit has failed the washer will not agitate properly. To check the mode shifter, first start the washer. Then when the washer starts agitating, look at the tub from the outside. If the whole inside tub is turning back and forth while in agitate, the mode shifter is bad. If the mode shifter is not bad then clear the code as described below and if the code reoccurs replace the motor. See the section on how to check the sifter coil below for more on this.
To clear the error code, turn the washer off. Then disconnect power for about 20 seconds. Next, reconnect power then open and close the lid five or more times within 12 seconds in the first 30 seconds of power-up.
Since I've removed the magnetic lid switch and spliced the wires to complete the circuit, how can I clear the error code? Only way without replacing the part that I can think is if I expose the 2 lid switch wires and touch them together 5+ times after plugging in... Which doesn't seem like the safest idea.
Since it's supposed to still operate, even with this error code, it seems it may actually be a shifter coil or motor issue... from that same page:
Note that on the early models the motor can cause the shifter coil to fail under the right conditions. The short version of this is that there is two 30-second time frames during a cycle that if you opened the lid of the washer and left it opened for more than a few minutes the shifter would fail. This is was an algorithm problem in the motor control board (located on top of the motor). This only applies to motors with the following part numbers on the motor 175d516g014, 175d516g015, 175d516g016, 175d516g026, 175d516g027, 175d516g028, 175d516g029, 175d516g030, 175d516g031.If your mode shifter has failed and your motor has one of these part numbers, you will need to replace the motor and the shifter to correct the problem.
Will have to try more on this tonight. In the meantime if anyone knows how I might clear the error code, I'm all ears.
  #5 (permalink)
Old 01-10-2012, 09:56 PM
Junior Member
Default
I guess this is just a big conversation with myself... well, maybe it can help others...
I got the replacement lid switch, installed it, reset the inverter board by opening/closing lid 10 times within a 12-second span on startup, and the washer ran like a charm.
I checked the light after the load was complete, and it was back to the 4-blink error code. I've since done two more loads by first unplugging then doing the reset -- I haven't tested to see if it will be OK on a 2nd load without doing a reset first.
I did find that it goes from a "waiting" status while filling with water (light goes on for 1 second, off for 1 second) to the 4-blink error exactly when it changes modes between initial fill into agitate. I think I may have one of the faulty motors listed that has the algorithm problem, and I wonder if it's something that has always existed without causing the washer to not run.
I will try another load without doing a reset and hope for the best -- if that doesn't work, it sounds like my only option is to replace the whole motor or get a new washer...
  #6 (permalink)
Old 06-08-2012, 08:14 PM
Junior Member
tlhrepairman is on a distinguished road
Default My washer has this problem.
I wanted to thank you for posting all this on here. I actually service appliances and i own a washer just like this, but i couldnt figure out what was wrong until i came across your posts.
My inner tub is turning when it agitates so obviously my Mode Shift has went out. I checked my motor and it isnt one of those listed, so thats good. Apparently it has been doing that for a while because over the last year the rubber straps that secure the tub have broken twice and it was due to the jerking of the tub along with the agitator. I reset the error code anyways, and its running right now, even in spin cycle. Looks like ill have to reset it before each load until I decide whether to buy the mode shift/shaft assembly or invest in a new washer.
Thanks for helping out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer does,nt spin or Agitate whitestar37 Washer Repair 0 08-08-2010 10:54 PM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 10:34 AM
Washer won't agitate or spin Scott B. Schafer Washer Repair 1 08-19-2009 04:09 PM
washer won't spin or agitate mnwild25 Washer Repair 1 11-17-2008 05:46 PM
