Discuss
Kenmore 80 - Doesn't spin when draining
 in
Washer Repair
I have a Kenmore 80 series washer that functions well overall. The problem is when the washer switches from "Agitation"
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 80 - Doesn't spin when draining
  #1 (permalink)
Old 01-04-2012, 08:56 AM
Junior Member
BenjaminA is on a distinguished road
Default Kenmore 80 - Doesn't spin when draining
Model Number: 23822100   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore 80 series washer that functions well overall. The problem is when the washer switches from "Agitation" mode, to drain/spin.
I hear the pump kick on and water starts going down, as well a motor noise, but the drum does not spin. I cannot move the drum by hand at all. (Locked hard). I did smell a little burning when it was left like this for a long time.
If I release the lid switch, everything starts shutting down, then CLUNK and something engages the drum and it moves just a little. Then I press the lid switch and it starts spinning and draining as normal.
Please forgive my ignorance, I read through the sticky posts, but wasn't quite sure.
Is it a brake not releasing? I can take video if needed. Thanks for any help!
Ads By Google
Related Models
Whirlpool 2382W00
Whirlpool 2382W1A
Whirlpool 2382W2A
Whirlpool 2382^00
Whirlpool 2382^1A
Whirlpool 2382^2A
Whirlpool 2384W0A
Whirlpool 2384W1A
Whirlpool 2384W2A
Whirlpool 2384W3A
Whirlpool 2384^0A
Whirlpool 2384^1A
Whirlpool 2384^2A
Whirlpool 2384^3A
Jenn-Air 2385EGN Surface Unit - Ddraft Ele
Jenn-Air 2385EGS Surface Unit - Ddraft Ele
Jenn-Air 2390ERS Surface Unit - Ddraft Ele
Whirlpool 2406W0A
Whirlpool 2406W1A
Whirlpool 2406W2A
Whirlpool 2406W3A
Whirlpool 2406^0A
Whirlpool 2406^1A
Whirlpool 2406^2A
Whirlpool 2406^3A
Whirlpool 2413W0A
Whirlpool 2413^0A
Whirlpool 2414W0A
Whirlpool 2414W1A
Whirlpool 2414W2A
Whirlpool 2414^0A
Whirlpool 2414^1A
Whirlpool 2414^2A
Whirlpool 2424W0A
Whirlpool 2424^0A
Whirlpool 2424^1A
Whirlpool 2426W0A
Whirlpool 2426W1A
Whirlpool 2426W2A
Whirlpool 2426^0A
Whirlpool 2426^1A
Whirlpool 2426^2A
General Electric 24488L0 Electric range
General Electric 24488W0 Electric range
Whirlpool 2453W0A
Whirlpool 2453W9A
Whirlpool 2453WAA
Whirlpool 2453^9A
Whirlpool 2453^AA
Whirlpool 2454X0A
Whirlpool 2454X1A
Whirlpool 2454X2A
Whirlpool 2454X3A
Whirlpool 2456X0A
Whirlpool 2456X1A
Whirlpool 2456X2A
General Electric 24588B0 Electric range
General Electric 24588L0 Electric range
General Electric 24588W0 Electric range
General Electric 24688B0 Electric range
General Electric 24688L0 Electric range
General Electric 24688W0 Electric range
Amana 2474.000 Mwave - Family Size (60 Hz)
Jenn-Air 2475 Surface Unit - Ddraft Ele
Jenn-Air 2475N Surface Unit - Ddraft Ele
Jenn-Air 2475S Surface Unit - Ddraft Ele
Amana 2476.000 Mwave - Family Size (60 Hz)
Jenn-Air 2480 Surface Unit - Ddraft Ele
Jenn-Air 2480N Surface Unit - Ddraft Ele
Jenn-Air 2480S Surface Unit - Ddraft Ele
Jenn-Air 2485 Surface Unit - Ele
Jenn-Air 2490 Surface Unit - Ele
Amana 2492.000 Mwave - Family Size (60 Hz)
Whirlpool 2492L0A
Whirlpool 2492L1A
Whirlpool 2492X0A
Whirlpool 2492^0A
Whirlpool 2492^1A
Amana 2494.000 Mwave - Family Size (60 Hz)
Amana 2494.001 Mwave - Family Size (60 Hz)
Amana 2494.A Mwave - Family Size (60 Hz)
Amana 2494.C Mwave - Family Size (60 Hz)
Amana 24940.A Mwave - Family Size (60 Hz)
Whirlpool 2496X0
Whirlpool 2496X1
Whirlpool 2496X2
Whirlpool 2496^0
Whirlpool 2496^0A
Whirlpool 2496^1
Whirlpool 2496^1A
Whirlpool 2496^2
Whirlpool 2496^2A
Amana 24C3SS Room Air Conditioner
Frigidaire 24CGMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN2 Tap(v2) / Gas Range
Frigidaire 24DEMBWAD4 Tap(v1) / Electric Range
Magic Chef 24FA-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FA-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FA-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FB-6CKXW
Magic Chef 24FG-6CKXW
Magic Chef 24FK-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FK-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FK-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FN-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FN-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FN-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FS-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FS-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FS-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FV-6CKXW
Magic Chef 24FY-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FY-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FY-6CKXWV8-DY Range - S/c Mwave Gas
Frigidaire 24HA241
Frigidaire 24HA241A
Frigidaire 24KEMAWAD3 Tap(v1) / Electric Range
Frigidaire 24KEMAWAD4 Tap(v2) / Electric Range
  #2 (permalink)
Old 01-04-2012, 01:45 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Go ahead and check the clutch and the brakes, but my fear is that something is wrong with the transmission. Your machine probably has neutral drains, that means the tub does not spin for a couple of minutes while it drains. After that time the timer pauses the motor, which causes the transmission to shift in tub drain mode.
I think what you are hearing when you lift the lid is a heavy shift by the transmission.
It may be that the timer is the problem, that it is not pausing and that the thud is just normal. I would start by replacing the timer and see if that fixes things.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 Series drops "lock" from drain to spin; spins while draining FalconFour Washer Repair 3 12-20-2010 06:14 AM
No Spin And Not Draining PPHILLIPS232 Washer Repair 6 03-24-2009 06:59 PM
Kenmore not draining completely csohio Washer Repair 1 12-23-2008 01:36 PM
Kenmore not draining or spinning Alicornat Washer Repair 2 07-20-2008 08:45 AM
Kenmore Dishwasher not draining landlord128 Dishwasher Repair 1 02-21-2008 11:27 AM
