On "normal" 54 min cycle washer fills and drum turns until the 48-46 mark. Time display goes to 6 mins. End of cycle light and spin speed light all go out. All lights around dial light up except "normal" which the dial is set on and "whitest whites". After about 2 mins, 43 mins comes up on display and then F20. Cancel the cycle and then it drains and door unlocks. Have to unplug to clear because push buttons don't do anything. Power back up and set dial to "rinse/spin" and time comes on to 25 mins and then I lose all lights except the "rinse/spin" at the dial. Cycle completes. On diagnostic test code F20 was on 2 times and F33 once. F33 happened on heavy duty cycle. Checked water valves, screens, hoses, air hose at water pressure valve, pump screen and made sure all connections were tight. Does that sounds like a bad ccu or panel?
It sounds like a bad CCU and I have seen this same problem in other machines where that was the problem.
Unfortunately you will have to replace it to be sure. If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions.
