Discuss
machine spins but dosnt agitate
 in
Washer Repair
machine will spin but will not agitate pulled motor and transmission off of barrel and turned shaft will spin one
Appliance Repair Forum > Appliance Repair Help > Washer Repair » machine spins but dosnt agitate
  #1 (permalink)
Old 07-07-2009, 03:55 PM
john morrill john morrill is offline
Junior Member
john morrill is on a distinguished road
Default machine spins but dosnt agitate
Brand: Kenmore   Age: 5 - 10 years
machine will spin but will not agitate pulled motor and transmission off of barrel and turned shaft will spin one way fine and will srin other way then lockup
  #2 (permalink)
Old 07-07-2009, 03:59 PM
Junior Member
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #3 (permalink)
Old 07-09-2009, 05:16 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Sounds like you will need a new transmission. Pull your agitator and check it first for any hang up in your agitator dogs or something else. If that is ok, likely problem is the tranny.
It is a little expensive, but given where you are on the tear down it is not much more work. Just take off the agitator, then remove the three bolts holding the transmission and pull it out. Slide the new one in and off you go.
Good luck, hope that fixes it for you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer spins but does not agitate ShelbyGuy Washer Repair 3 02-22-2010 06:35 PM
won't agitate but spins looz98 Refrigerator & Freezer Repair 0 07-27-2009 06:17 PM
Spins but will not agitate dastaines Washer Repair 2 06-27-2009 05:18 PM
Crosley Spins but won't Agitate slipknotkod Washer Repair 1 02-23-2009 03:15 PM
Won't agitate but spins BobKrause56 Dishwasher Repair 2 05-13-2008 08:30 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
