Discuss
Kenmore HE3 Washer Tub out of balance?
 in
Washer Repair
My 4 year old HE3 started making noise in the spin cycle a couple of weeks ago and is getting
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore HE3 Washer Tub out of balance?
  #1 (permalink)
Old 07-06-2009, 09:47 PM
Junior Member
smitty33 is on a distinguished road
Default Kenmore HE3 Washer Tub out of balance?
Model Number: 110.45872400   Brand: Kenmore   Age: 1 - 5 years
My 4 year old HE3 started making noise in the spin cycle a couple of weeks ago and is getting worse. Inspecting today, I found white shavings inside the rubber seal between the door and tub, I also found that the white plastic rim connecting the rubber seal to the tub is cracked. It also seems that the front of the tub (towards the door) is an inch too low. Holding it up makes the tub manually spin much easier. Help! I've taken the back off this machine before to unclog the drain, so i'm not a rookie... but no expert. Thanks!!!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 07-08-2009, 10:26 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
With the back off you should be able to see where the problem in your suspension is.
The tub is held up with 4 shock absorbers and 2 springs. Also the concrete counter weights serve a suspension purpose. One of these things is broken or not in the right configuration.
When you get the tub suspended correctly you may be able to get by with the cracked plastic piece, you will just have to wait and see.
Good luck, let us know what you find out.
__________________
  #3 (permalink)
Old 07-08-2009, 10:48 PM
Junior Member
Default OK, here I go
OK, my wife is giving me until Monday to fix it or the Sears guy is coming (with his big bill). Looking again, that white cracked plastic looks broken 180 degrees around the tub. I'll try to align the tub, but in case I need a new plastic rim/rubber seal, could you send the link to the part? Thanks.. I'll reply my findings tomorrow.
  #4 (permalink)
Old 07-09-2009, 02:58 PM
Senior Expert
APP Volunteer
Default
Hi Smitty
Without being there I am no absolutely certain what part you need, but see if this is the part you need.
Part number: AP3773838
If there is any doubt call APP and discuss the part with them.
Good luck, Hope you avoid the dreaded and expensive Sears Repair Call. Let us know how it turns out,
__________________
  #5 (permalink)
Old 07-09-2009, 07:21 PM
Junior Member
Angry Further inspection....
I took the top off of the washer and found that both springs, all 4 hydrollic legs, and the cement weight all on top appear to be working/in place. It looks like the part you have above is the right one, but looks incredibly hard to replace. Turns out the white plastic rim is a barrier between the inner and outer lining of the tub, so I'm not sure or not if the entire tub is out of alignment or not. I can't hardly see or reach where the rubber connects to this part and I'm pretty sure I'd have to remove the entire tub from the back to replace it, correct?
I'm hoping that this part broke because of poor quality of the orginal and nothing else caused it. If you think an intermediate level guy can pull this off, please send a few more scecific instructions if you know. Thanks!!!
  #6 (permalink)
Old 07-10-2009, 07:32 AM
Senior Expert
APP Volunteer
Default
You should be able to replace the part, but it will take some time and patience. I strongly advise having a helper, and just taking it slow and steady.
Here is the Service Manual (your machine is a Whirlpool Duet masquerading as a Sears product)
https://secured.whirlpool.com/Servic...0Job%20Aid.pdf
Good luck, let us know how it turns out.
__________________
  #7 (permalink)
Old 07-10-2009, 09:36 AM
Junior Member
SearsCare is on a distinguished road
Default Washer repair
To Smitty33,
My name is Brian and I am part of the Sears Cares escalations team. I know you are trying to do this repair yourself and I do hope you can get it done with no problems. If it comes to a point where it is not viable for you, please reach out to me and my team. We have some service options that will save you some money on the repair, if you decide to have a Sears certified tech come to your home and provide the service. At your convenience, please contact our office at searscares@searshc.com so that we can talk more about what we can do to help. When you have a moment, please send an email. Please provide a contact phone number and the phone number the washer was purchased under (if different than the contact phone number) and we will call you directly. In addition, please provide the screen name (Smitty33) for reference to this issue and we do look forward to talking to you soon.
Thank you,
Brian J.
Senior Case Manager
Sears Cares
  #8 (permalink)
Old 07-10-2009, 02:12 PM
Junior Member
Default Update... HE3 tub issues
Sears repair called and came this AM. Good news, the nice man gave us a free estimate. Bad news, he thought the rear bearing was out and all together would cost about $700 to fix. Not sure how he knew the bearing was bad. I can buy/replace the white plastic rim ($150) on the front of the tub, but no one has told me if I can do this from the front or if I need to take the entire tub out the back.
Thanks for any help
  #9 (permalink)
Old 07-10-2009, 02:33 PM
Senior Expert
APP Volunteer
Default
Hi Smitty
Take a good long look at the Service Manual and then you can decide if you want to attempt the repair.
A rear bearing failure might have caused your damage, so you need to be prepared to fix that also.
These machines are great when they work, but when they do not the repairs are complicated and expensive. If you decide to go with a new washer I would recommend a basic top loader, it will do a great job for you, cost less than any other option, be easy to repair and be less likely to need repair.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore front load washer drum off balance and bangs in one location kemily Washer Repair 5 05-30-2014 07:59 PM
Ge Washer Out Of Balance.......... FDAR Washer Repair 7 03-03-2010 01:12 PM
how do i balance my washer jaimiecapalbo Washer Repair 1 11-20-2009 05:19 PM
Off balance washer Peanut24 Washer Repair 1 09-12-2009 07:15 PM
washer won't balance rthurber Washer Repair 1 08-10-2009 04:54 PM
