crazy problem. i have a peice of clothing stuck under the agitator. i found some information on some of the blogs, but it looks like all the blogs refer to the removal of a 1/2" bolt. this washer doesent have this 1/2" bolt. i found the diagram for this washer, it dosent show a bolt. just need to know how to remove the auger / agitator. any help would be awsome. thank you.
Have you taken the cap off the agitator and looked for yourself? If there is no bolt there may just be a retainer that you turn with the square end of a ratchet extension.
