Winther
#1 Posted : Monday, July 6, 2009 3:47:41 PM(UTC)
Winther
Hey everyonme
just replaced the snubber due to my washer not working on the spin cycle. that worked but now it doesnt want to work on the wash cycle it stops the motor. Any idea what may be the problem?:confused: ?
Any help would be great
Thanks Ty
MPHCO
#2 Posted : Tuesday, July 7, 2009 11:25:27 AM(UTC)
MPHCO
Can you give a better description of what is happening?
I just went through a bunch of issues with my Maytag that involved the snubber, brake, transmission. See this thread for some descritptions of how I went through it. You may find something to help you.
http://forum.appliancepartspros...-parts-2.html#post103328
magician59
#3 Posted : Tuesday, July 7, 2009 1:52:50 PM(UTC)
magician59
Does it fill? Will it drain and spin? Remove the belt and select a spin cycle, and see if the motor is running.
Winther
#4 Posted : Tuesday, July 7, 2009 4:55:58 PM(UTC)
Winther
ok well here is a little more it will fill, drain and spin fine now (would not spin before the new snubber). the motor turns fine with out the belt, i can turn the belt counter clockwise and make the thrust washer go down and turn the power on wash cycle it ingages the thrust washer and stops everything like the clutch is froze.
Hope that gives everyone a little more info
Thanks Ty
MPHCO
#5 Posted : Tuesday, July 7, 2009 5:53:54 PM(UTC)
MPHCO
Hmm. OK. So with the belt on, it will spin and drain via the motor. So, the brake seems to be ok that way, and the pump appears ok.
With the belt off, can you turn the transmission pulley CW (looking up)? This is what drives the agitation cycle in the transmission. If it will not turn by hand that direction, you may need to take a closer look at the transmission.
Winther
#6 Posted : Tuesday, July 7, 2009 10:00:07 PM(UTC)
Winther
yea it will not turn by hand CW, locked up tight
MPHCO
#7 Posted : Wednesday, July 8, 2009 12:21:27 PM(UTC)
MPHCO
So it seems like you need to determine if in fact the thrust bearing assembly is working correctly, or if its the transmission. I'm not sure of the best way. You could take out the brake assembly and see if you can then get the transmission to turn in the CW direction. did you replace the brake rotor and stator?
