I have a slow leak into the tub of the washer. I assume it is the water valve. Does that make sense?
When I look for the part it shows "Prior to Ser Pre 18" or "Ser Pre 18 and later" How do I know which model I have? Serial # is 20897132ZD.
Thanks!
Yes, a faulty water valve would cause that to happen. You have Ser Pre 18 and later, it's going by the first two digits of your serial number.
Originally Posted by: ApplianceJunk Yes, a faulty water valve would cause that to happen. You have Ser Pre 18 and later, it's going by the first two digits of your serial number. Thank for your help!
Originally Posted by: ApplianceJunk Yes, a faulty water valve would cause that to happen. You have Ser Pre 18 and later, it's going by the first two digits of your serial number. I have an Atlantis model MAVT634AWW with s/n 24538149EN that has a slow dribble of water into the tub all the time on the cold side of the supply . If I switch the hoses and use the hot side only it does not dribble water. I am testing this machine in the garage where I only have a cold water supply but I dont think that would make any difference. The parts listing shows two different water valves with one being I presume a std type and the other on being listed as a 60/40 type. If I replace the valve to stop the dribble into the tub which I presume is the problem which one should I order ?
