| » Washer stops on regular cycle |
Model Number: lat9606aae Brand: Maytag Age: 5 - 10 years
My washer is stoping on the regular cycle. It works fine on all others? What is my problem part? Thanks
At what point exactly it stops?
Post as much information as possible. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The washer will not stop everytime but only on the regular cycle it may stop when the water fills up to rinse before spinning out. All other cycles have no issues. This is a Maytag Washer model LAT9606AAE serial #222915165w. Thanks for any help you can provide !!
If it stops before water fills up - most likely the problem is the water inlet valve.
If it stops after water filled up, then the problem is the timer. - The part number for the water valve is AP251108 - The part number for the timer is AP250938 - Here are the break down diagrams for the Maytag washer Model LAT9606AAE Good luck. Gene.
__________________
| Display Modes | |
| Maytag SE 1000 washer stops mid cycle or won't start wash cycle | katyat | Washer Repair | 1 | 09-11-2009 04:15 PM |
| Washer will not go through rinse or spin cycle on regular cycle | dhilde7165 | Washer Repair | 0 | 02-14-2009 04:10 PM |
| Maytag wash won't spin on regular cycle but will on gentle cycle | BlazingSun | Washer Repair | 0 | 01-07-2009 08:41 PM |
| Washer loads water then stops on regular/perm press OK/Timer? | JillD | Washer Repair | 0 | 07-07-2008 09:52 PM |
| Maytag Performa Washer won't spin or wash on regular cycle | gidy34 | Washer Repair | 1 | 11-14-2007 09:54 AM |
