Tinababiak
#1 Posted : Monday, July 6, 2009 9:42:33 AM(UTC)
Tinababiak
Error f11 jams mashine. I tried unplugging for awhile and many restarts. Machine fills then stops with error F11. What to do?
sidfink43
#2 Posted : Tuesday, July 7, 2009 3:35:23 PM(UTC)
sidfink43
Hi Tina
If you will take off the bottom front panel (two screws) you will find a tech sheet and trouble shooting instructions.
What is happening is that after your machine fills, the central control unit tells the motor control board to start the motor and start washing. After a while, if the motor control board does not report back to the CCU that the motor has started and washing has begun, the CCU shuts down the washer.
This may be a wiring problem (check for frayed wires or shorts) but more likely a failure of one of the boards. See if the troubleshooting helps you figure out which one, but if you have to make a guess I think it is more likely the motor control board.
Good luck, let us know what you find out.
__________________
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool Duet Washer - Wire broken off connector on harness (Washer Repair)
by Cephalon 1/21/2021 9:33:49 PM(UTC)
Whirlpool Duet Washer Codes (Washer Repair)
by mbocon 3/10/2020 5:04:51 PM(UTC)
Whirlpool duet washer (Dishwasher Repair)
by Julia Johnson 11/1/2017 9:53:41 AM(UTC)
What happened to my Whirlpool Duet washer?? (Washer Repair)
by colbran 10/2/2017 12:01:48 PM(UTC)
Whirlpool Duet Washer (Washer Repair)
by Bmbrouillette 7/2/2017 11:05:32 AM(UTC)
Whirlpool duet washer- won't start after replacing CCU and door latch (Washer Repair)
by Ivanick 5/22/2017 6:07:41 PM(UTC)
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
whirlpool duet washer F06 E02 error (Washer Repair)
by tnafranklin 10/18/2016 12:47:55 PM(UTC)
whirlpool duet washer (Washer Repair)
by Oathose 4/4/2016 7:23:01 PM(UTC)
Whirlpool Duet Washer bellow tore in two. (Washer Repair)
by pitwoman 1/28/2016 5:42:42 PM(UTC)
by CrosbyFamilyFarm 12/31/2015 1:28:32 PM(UTC)
Whirlpool Duet Washer not working (Washer Repair)
by Shanej69 11/23/2015 1:59:18 PM(UTC)
Whirlpool Duet washer start button is broken (Washer Repair)
by bjgamble 9/7/2015 7:04:46 AM(UTC)
