| » Rinse cycle will start filling and stop with little water |
Model Number: MAH3000AGW Brand: Maytag Age: 1 - 5 years
In any Mode, It will run perfectly until RINSE, when it starts filling and suddenly stops with very little water, the Cycle will continue, so you need to add water manually. Tried changing the valve, but did not work, the repair man says that we could try changing the Control Panel and Timer, think this is just a try/fail solution and very expensive.
ANy suggestions ? could it be the Rinse fill switch? Tks for yr help Ads By Google Related Models |
You are right, the tech is doing a "try and see if this works" approach, but that is what you do with this model.
If you buy the parts from this site and they do not fix the problem you can return them, see the returns policy for details and instructions. Also, visually check the board for any burned resistors and if you have not changed out the wax motors, you need to do so.
__________________
Yeah, sorry the try the parts approach does not work for Argentina.
Your model is one of the most troubled machines ever made, and about the only thing I can do is link you to a service manual for the model. https://docs.google.com/viewer?a=v&p...1OWNm&hl=en_US There is just no way we can give you a definitive analysis for your problems with your machine, and if a new washer is an option I would strongly urge you to consider that. Good luck, sorry not to be of more help.
__________________
| Display Modes | |
| Water wont stop running in the first fill and again at the rinse cycle | Dadrocks40 | Washer Repair | 3 | 04-10-2011 05:43 AM |
| Water wont stop running in the first fill and again at the rinse cycle | Dadrocks40 | Washer Repair | 0 | 03-27-2011 08:32 PM |
| washer won't stop filling with water and go to wash cycle | dawn spoores | Washer Repair | 1 | 01-24-2011 09:15 AM |
| Washer fills on wash cycle and rinse cycle and won't stop filling! | riphinney | Washer Repair | 15 | 03-12-2008 05:30 PM |
| Water filling tub for rinse cycle takes forever | Cheryl B | Washer Repair | 4 | 02-15-2008 12:38 PM |
