| » Whirlpool wont agitate |
Model Number: LSR7233DQ1 Brand: Whirlpool Age: 1 - 5 years
This is a 2nd hand machine so I don't know the age or how to guess it. The problem is the agitator is locked up, cant be turn by hand in ether direction. The tub fills with water and drains.
I'm mechanical with small engines but have never worked on appliances. Would like help with some simple checks to see if the machine is worth fixing or to be used as a boat anchor. I would prefer to fix if possible as funds are limited. Thanks in advance. Ads By Google Related Models |
The question here is what is the motor doing when it is supposed to be agitating or spinning. You said it drains but did not say if it spins.
Take off the cabinet and operate it and see if the motor is turning after it fills. If not, it could be that the transmission is jammed. It may also be that the agitator is jammed with broken cams or "dogs", these parts here. Part number: AP3119063
__________________
| Display Modes | |
| whirlpool washer will agitate, but wont spin or drain | robert garbacz | Washer Repair | 5 | 04-11-2011 07:26 AM |
| Whirlpool washer wont spin or agitate. | sillyman | Washer Repair | 2 | 08-03-2010 12:29 PM |
| wont agitate | mila | Washer Repair | 1 | 01-16-2010 04:16 PM |
| Whirlpool Direct Drive grinding noise wont agitate or rotate | neverswt | Washer Repair | 3 | 02-28-2009 09:29 AM |
| Washer wont stop filling/wont agitate | khart26 | Washer Repair | 1 | 08-05-2008 11:58 AM |
