| » F11 Error Code |
Hi Mary
If you will take off the bottom front panel (two screws) you will find a tech sheet and trouble shooting instructions. Your machine has a computer control board which is the main brain, and a motor control board which as its name implies, manages the motor. Your error code says that the two boards are not talking to one another. This may be a wiring problem (check for frayed wires or shorts) but more likely a failure of one of the boards. See if the troubleshooting helps you figure out which one, but if you have to make a guess I think it is more likely the motor control board. Good luck, let us know what you find out.
__________________
| Display Modes | |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| error code 40 | kimbrecht69@hotmail.com | Oven Repair (including Ranges and Cooktops) | 0 | 10-19-2009 07:14 PM |
| GE error code F3 | Mako | Oven Repair (including Ranges and Cooktops) | 20 | 04-10-2008 09:03 PM |
| F33 error code | daphil | Washer Repair | 1 | 03-27-2008 06:02 PM |
| error code f13 | banks | Oven Repair (including Ranges and Cooktops) | 1 | 01-17-2008 11:11 AM |
