Discuss
Maytag Washer fills only
 in
Washer Repair
My maytag washer fills and thats it. Sometimes I turn it off and turn the timer to spin it will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer fills only
  #1 (permalink)
Old 01-01-2008, 02:54 PM
Mark767 Mark767 is offline
Junior Member
Mark767 is on a distinguished road
Default Maytag Washer fills only
Model Number: lat4915AAE   Brand: Maytag   Age: More than 10 years
My maytag washer fills and thats it. Sometimes I turn it off and turn the timer to spin it will drain and spin. The lid switch checks good, the water level switch cks good. The washer is 12 years old never had a problem. I checked for voltage to the motor and all the legs have voltage. I have a good ground on pin 7 of the water level switch. I cleaned the timer switched with contact cleaner. I am thinking it may be the timer, could it be the motor start switch??? Please help if posible....thanks..
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-02-2008, 03:17 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the voltages to the motor check out ok, check the common pin ohms to any winding, probably find an open internal motor thermal shutoff.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills when off kbncpa Washer Repair 1 11-04-2007 12:49 PM
washer fills with water then run program cancels Doug Quinn Washer Repair 0 11-03-2007 09:39 PM
Washer fills but does not move or drain RedScott Washer Repair 3 10-27-2007 05:00 PM
GE Washer Tank Fills but No Spin/Wash/Drain jrgreulich Washer Repair 3 09-02-2007 06:09 PM
washer fills but won't agitate jamesamc Washer Repair 1 07-24-2007 03:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
