| » GE washer wont spin |
Model Number: wwse3160aoww Brand: GE Age: 1 - 5 years
Washer agitates but doesnt spin. Belt seems fine. I have ran it with front off and motor runs during spin cycle. Sometimes basket spins a little but not under heavy load. I removed clutch disassembled and cleaned it well with wire brush. A lot of lining left on clutch still. Reassembled and same problem. If it is the clutch is there something I should physically see while inspecting it? Any other thoughts? Transmission maybe?
Thank you. Ads By Google Related Models |
Yes, it sounds like your clutch is ok. The transmission will have the brake assembly inside so either way that may fix your problem.
If you buy the parts from this site and they do not fix the problem you can return them, see the returns policy for details and conditions, of which there are few. Good luck, hope this works for you.
__________________
GE is very tight with their technical data and does not release it.
See if this service manual will help you, it may be close enough to your model to tell you how to do the job. http://appliancejunk.com/forums/inde...=view;down=310
__________________
| Display Modes | |
| washer wont spin, than wont stop filling | lizzard | Washer Repair | 1 | 11-30-2011 06:07 PM |
| Washer wont spin | gbroughton | Washer Repair | 1 | 05-21-2010 06:56 PM |
| washer wont spin | jimconnolly | Washer Repair | 4 | 11-10-2009 07:18 PM |
| Roper washer wont spin and wont empty | jgirl14572 | Washer Repair | 2 | 10-11-2009 06:54 AM |
| washer wont spin | cwhitsett | Washer Repair | 2 | 03-19-2009 01:13 PM |
