Discuss
Whirlpoo timer or switch or ?
 in
Washer Repair
My whirlpool top loading washer has a pullout knob and circular indicator dial on the timer. The dial has 3
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpoo timer or switch or ?
  #1 (permalink)
Old 07-03-2009, 04:24 PM
sjspaulding sjspaulding is offline
Junior Member
sjspaulding is on a distinguished road
Default Whirlpoo timer or switch or ?
Model Number: LA5580XSN1   Brand: Whirlpool   Age: More than 10 years
My whirlpool top loading washer has a pullout knob and circular indicator dial on the timer. The dial has 3 cycles: Permanent Press, Knits/Gentle, and Regular. Each cycle beginnings with a fill and agitate region (includes high and low speed agitation portions of varying lengths depending on the cycle), then a drain and rinse region, then a spin and rinse region. In the drain and rinse region is a dot that you can turn to after a cycle is done to get an extra rinse and spin for soapy or extra dirty loads. The spin region may include high and low speed spins with spray rinse or full rinse sections depending on the cycle.
Now when we turn it on at any cycle it fills and goes into a high speed agitation, which it continues through the whole cycle until it turns off at the end. The indicator knob on the timer advances but there are no changes in the washing action.
However, after it stops at the end of the cycle, you can advance the timer knob to a spin region on any of the cycles and it will drain and spin through the spin cycle until turning off. But it doesn't go through any intermediate spray and rinses, etc.
When the basket is empty of water you can also turn the timer knob to any one of the dots on the cycles and it will fill and agitate and eventurally turn off, but it never spins. Again the knob advances through the cycle but nothing else happens.
From what I have been reading in the answers, the best indicator of a timer problem is the spin not working in just one of the cycles. In my case the same thing happens in all of the cycles. And in all of the cycles I can get it to spin after completing a whole cycle, but the timer won't activate any of the intermediate variations.
Related Models
Whirlpool LA5580XSW0
Whirlpool LA5580XSW1
Whirlpool LA5580XSW2
Whirlpool LA5580XSW3
Whirlpool LA5580XTF0
Whirlpool LA5580XTF1
Whirlpool LA5580XTG0
Whirlpool LA5580XTG1
Whirlpool LA5580XTM0
Whirlpool LA5580XTM1
Whirlpool LA5580XTN0
Whirlpool LA5580XTN1
Whirlpool LA5580XTW0
Whirlpool LA5580XTW1
Whirlpool LA5588XYG0
Whirlpool LA5588XYN0
Whirlpool LA5588XYW0
Whirlpool LA5590XPW0
Whirlpool LA5590XPW1
Whirlpool LA5591XPW3
Whirlpool LA5591XPW4
Whirlpool LA5599XPW4
Whirlpool LA5600XKW0
Whirlpool LA5600XKW1
Whirlpool LA5600XKW2
Whirlpool LA5600XMW0
Whirlpool LA5600XPW0
Whirlpool LA5600XPW1
Whirlpool LA5600XPW3
Whirlpool LA5600XPW4
Whirlpool LA5600XPW5
Whirlpool LA5600XPW6
Whirlpool LA5600XPW7
Whirlpool LA5600XSW0
Whirlpool LA5600XSW1
Whirlpool LA5600XSW2
Whirlpool LA5600XTF0
Whirlpool LA5600XTF1
Whirlpool LA5600XTG0
Whirlpool LA5600XTG1
Whirlpool LA5600XTM0
Whirlpool LA5600XTM1
Whirlpool LA5600XTN0
Whirlpool LA5600XTN1
Whirlpool LA5600XTW0
Whirlpool LA5600XTW1
Whirlpool LA5605XKW1
Frigidaire LA560AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA560AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA560AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA560JXD3 Wwh(v1) / Washer
Frigidaire LA560JXD4 Wwh(v1) / Top Load Washer
Frigidaire LA560JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA560JXF3 Wwh(v2) / Washer
Frigidaire LA560JXF4 Wwh(v2) / Top Load Washer
Frigidaire LA560JXH3 Wwh(v3) / Washer
Frigidaire LA560JXH4 Wwh(v3) / Top Load Washer
Frigidaire LA560JXV3 Wwh(v4) / Washer
Frigidaire LA560JXV4 Wwh(v4) / Top Load Washer
Frigidaire LA560JXW3 Wwh(v5) / Washer
Frigidaire LA560JXW4 Wwh(v5) / Top Load Washer
Frigidaire LA560JXW5 Wwh(v2) / Top Load Washer
Frigidaire LA560MXD1 Wwh(v3) / 27 " Washer
Frigidaire LA560MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560MXH2 Wwh(v3) / 27 " Washer
Frigidaire LA560MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA560MXW2 Wwh(v1) / 27 " Washer
Whirlpool LA5610XTF0
Whirlpool LA5610XTG0
Whirlpool LA5610XTG1
Whirlpool LA5610XTM0
Whirlpool LA5610XTN0
Whirlpool LA5610XTN1
Whirlpool LA5610XTW0
Whirlpool LA5610XTW1
Whirlpool LA5668XSW0
Whirlpool LA5668XSW1
Whirlpool LA5668XSW2
Whirlpool LA5668XTF1
Whirlpool LA5668XTG1
Whirlpool LA5668XTM1
Whirlpool LA5668XTN1
Whirlpool LA5668XTW0
Whirlpool LA5668XTW1
Whirlpool LA5700XKW0
Whirlpool LA5700XMW0
Whirlpool LA5700XMW1
Whirlpool LA5700XPW0
Whirlpool LA5700XPW1
Whirlpool LA5700XPW3
Whirlpool LA5700XPW4
Whirlpool LA5700XPW5
Whirlpool LA5700XPW6
Whirlpool LA5700XSW0
Whirlpool LA5700XSW1
Whirlpool LA5700XSW2
Whirlpool LA5700XTF0
Whirlpool LA5700XTF1
Whirlpool LA5700XTG0
Whirlpool LA5700XTG1
Whirlpool LA5700XTM0
Whirlpool LA5700XTM1
Whirlpool LA5700XTN0
Whirlpool LA5700XTN1
Whirlpool LA5700XTW0
Whirlpool LA5700XTW1
Whirlpool LA5705XKW0
Whirlpool LA5705XMW0
Whirlpool LA5705XMW1
Whirlpool LA5705XTF0
Whirlpool LA5705XTF1
Whirlpool LA5705XTF2
Whirlpool LA5705XTG0
Whirlpool LA5705XTG1
Whirlpool LA5705XTG2
Whirlpool LA5705XTM0
Whirlpool LA5705XTM1
Whirlpool LA5705XTM2
Whirlpool LA5705XTN0
  #2 (permalink)
Old 07-03-2009, 07:05 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
It sounds to Me like the timer has failed. Without a pause in the timer, The motor never shuts off, Therefore, It can't reverse direction, which would make it drain and spin.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
switch knob or timer edman turner Dryer Repair 1 01-21-2009 06:42 AM
timer switch David J Domin Washer Repair 0 11-18-2008 02:42 PM
Switch or timer rebel#3 General Talk 1 10-08-2008 11:01 PM
new timer switch markwalter98 Dryer Repair 0 09-19-2008 09:26 AM
Whirlpoo Dryer BALTAZAR RAFAEL CORTES Dryer Repair 1 11-05-2007 07:17 PM
