Discuss
whirlpool ultimate care 2
 in
Washer Repair
My washer has a strong smell while in the wash and spin modes. It doesnt smell like electrical more like
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool ultimate care 2
  #1 (permalink)
Old 07-03-2009, 10:02 AM
higleyml higleyml is offline
Junior Member
higleyml is on a distinguished road
Default whirlpool ultimate care 2
Model Number: lsq9549pg0   Brand: Whirlpool   Age: 5 - 10 years
My washer has a strong smell while in the wash and spin modes. It doesnt smell like electrical more like a burnt car clutch or rear end gear burning(it is coming from the bottom of the machine). I took it out today and I have a small amount of fluid build up on the coupler which has the same smell (no other appearent fluid leaks or build ups). I cant tell if this fluid came from the motor or the transmission, I am suspecting the transmission. Any inputs? Also if I have to change the transmission does the drive shaft just slide out or is it clipped up in the clutch area? The machine operates fine just has that smell.
Thank You
Mike
Related Models
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
Whirlpool LSQ9549PW1 Automatic Washer
Whirlpool LSQ9549PW2 Automatic Washer
Whirlpool LSQ9549PW3 Automatic Washer
Whirlpool LSQ9549PW5 Automatic Washer
Whirlpool LSQ9549PW6 Automatic Washer
Whirlpool LSQ9550PW0 Automatic Washer
Whirlpool LSQ9550PW1 Automatic Washer
Whirlpool LSQ9550PW2 Automatic Washer
Whirlpool LSQ9550PW3 Automatic Washer
Whirlpool LSQ9550PW4 Automatic Washer
Whirlpool LSQ9560PW0 Automatic Washer
Whirlpool LSQ9560PW1 Automatic Washer
Whirlpool LSQ9560PW3 Automatic Washer
Whirlpool LSQ9560PW4 Automatic Washer
Whirlpool LSQ9564JQ0
Whirlpool LSQ9564JQ1
Whirlpool LSQ9564JT0
Whirlpool LSQ9564JT1
Whirlpool LSQ9564JZ0
Whirlpool LSQ9564MQ0 Automatic Washer
Whirlpool LSQ9600JQ0
Whirlpool LSQ9600JQ1
Whirlpool LSQ9600JT0
Whirlpool LSQ9600JT1
Whirlpool LSQ9600LG0
Whirlpool LSQ9600LG1 Automatic Washer
Whirlpool LSQ9600LW0
Whirlpool LSQ9600LW1 Automatic Washer
Whirlpool LSQ9610JQ0
Whirlpool LSQ9610JQ1
Whirlpool LSQ9610JT0
Whirlpool LSQ9610JT1
Whirlpool LSQ9610LG0 Automatic Washer
Whirlpool LSQ9610LW0 Automatic Washer
Whirlpool LSQ9620LG0
Whirlpool LSQ9620LG1 Automatic Washer
Whirlpool LSQ9620LW0
Whirlpool LSQ9620LW1 Automatic Washer
Whirlpool LSQ9645KQ0
Whirlpool LSQ9645KQ1
Whirlpool LSQ9645KT0
Whirlpool LSQ9645KT1
Whirlpool LSQ9650PG0 Automatic Washer
Whirlpool LSQ9650PG1 Automatic Washer
Whirlpool LSQ9650PG2 Automatic Washer
Whirlpool LSQ9650PG3 Automatic Washer
Whirlpool LSQ9650PG4 Automatic Washer
Whirlpool LSQ9650PW0 Automatic Washer
Whirlpool LSQ9650PW1 Automatic Washer
Whirlpool LSQ9650PW2 Automatic Washer
Whirlpool LSQ9650PW3 Automatic Washer
Whirlpool LSQ9650PW4 Automatic Washer
Whirlpool LSQ9659LG0
Whirlpool LSQ9659LG1 Automatic Washer
Whirlpool LSQ9659LW0
Whirlpool LSQ9659LW1 Automatic Washer
Whirlpool LSQ9659PG0 Automatic Washer
Whirlpool LSQ9659PG1 Automatic Washer
Whirlpool LSQ9659PG2 Automatic Washer
Whirlpool LSQ9659PG3 Automatic Washer
Whirlpool LSQ9659PG4 Automatic Washer
Whirlpool LSQ9659PW0 Automatic Washer
Whirlpool LSQ9659PW1 Automatic Washer
Whirlpool LSQ9659PW2 Automatic Washer
Whirlpool LSQ9659PW3 Automatic Washer
Whirlpool LSQ9659PW4 Automatic Washer
Whirlpool LSQ9660PG0 Automatic Washer
Whirlpool LSQ9660PG1 Automatic Washer
Whirlpool LSQ9660PG2 Automatic Washer
Whirlpool LSQ9660PG3 Automatic Washer
Whirlpool LSQ9660PG4 Automatic Washer
Whirlpool LSQ9660PW0 Automatic Washer
Whirlpool LSQ9660PW1 Automatic Washer
Whirlpool LSQ9660PW2 Automatic Washer
Whirlpool LSQ9660PW3 Automatic Washer
Whirlpool LSQ9660PW4 Automatic Washer
Whirlpool LSQ9665JQ0
Whirlpool LSQ9665JQ1
Whirlpool LSQ9665JQ2
Whirlpool LSQ9665JQ3
Whirlpool LSQ9665JQ4
Whirlpool LSQ9665JT0
Whirlpool LSQ9665JT1
Whirlpool LSQ9665JT2
Whirlpool LSQ9665JT3
Whirlpool LSQ9665JT4
Whirlpool LSR4100HQ0
Whirlpool LSR4311DQ0
Whirlpool LSR5100HQ0
Whirlpool LSR5100KQ0
Whirlpool LSR5100LQ0
Whirlpool LSR5101LQ0
Whirlpool LSR5101LQ1 Automatic Washer
Whirlpool LSR5102LQ1 Automatic Washer
Whirlpool LSR5121HQ0
Whirlpool LSR5121JQ0
Whirlpool LSR5132AG0
Whirlpool LSR5132AN0
Whirlpool LSR5132AW0
Whirlpool LSR5132HQ0
Whirlpool LSR5132HQ1
Whirlpool LSR5132JQ0
Whirlpool LSR5132JQ2
Whirlpool LSR5132PQ0 Automatic Washer
Whirlpool LSR5132PQ1 Automatic Washer
Whirlpool LSR5132PQ3 Automatic Washer
Whirlpool LSR5132PQ4 Automatic Washer
Whirlpool LSR5232DW0
Whirlpool LSR5232LQ0
Whirlpool LSR5232LQ1 Automatic Washer
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0
  #2 (permalink)
Old 07-04-2009, 07:09 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Hi Hig
Odors and noises are the hardest things we deal with in a Forum because we aren't there to smell or hear what is going on, which is the first diagnostic.
Sounds like your transmission might be leaking. If you want to examine it, to take it out, first take off the agitator. Then take off the pump, motor, and coupling. Three bolts hold the transmission in and after you take them out, carefully slide the transmission out and inspect it.
Good luck, let us know what you find.
__________________
  #3 (permalink)
Old 07-04-2009, 09:27 PM
Junior Member
Default
Thank you for the reply, is there a seal on the motor side that can go bad? The fluid I have on the couple is thick and smells like gear lube. I know the motor shafts have internal lube but it always reminded me of common grease. If the trans is leaking can that be fixed or is it a replacement?
  #4 (permalink)
Old 07-05-2009, 07:35 AM
Senior Expert
APP Volunteer
Default
The general recommendation is that you replace the transmission with a new unit. I have seen posts on some sites where folks have attempted, (in some cases successfully) to repair one, but I think that was more for the challenge then to save money. If it were me I would replace it with a new one and be done with it.
Good luck, let us know what you decide to do.
__________________
  #5 (permalink)
Old 07-05-2009, 12:04 PM
Junior Member
Default
I figured that was the case since I didnt see a seal on the parts list. Ok I will order a transmission and go from there! Thank you again for the responses.
Mike
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Ultimate Care II - lid switch washerhelp13 Washer Repair 1 01-20-2010 12:05 PM
whirlpool ultimate care II washer queen_dior Washer Repair 1 07-31-2009 11:51 AM
Whirlpool Gold Ultimate Care II moclause Dryer Repair 1 04-11-2009 08:35 PM
whirlpool ultimate care clotheswasher trouble1 Dishwasher Repair 1 01-03-2009 09:48 PM
Whirlpool Ultimate Care II Washer Elise Washer Repair 0 08-08-2007 10:27 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
