I have a Lady Kenmore 3 speed Heavy Duty 90 series washing machine. Model #92093100. When plugged in I can hear power, however it does not run. I go to various cycle on the cycle switch nothing happens. Can I have some advice as to what the problem is, so I can repair it.
aloha Robert
You have provided rather limited information, so I am going to assume that the machine fills, does not run and then empties. If so, check the coupling, this part here. Part number: AP3963893
Originally Posted by: Robert R. I have a Lady Kenmore 3 speed Heavy Duty 90 series washing machine. Model #92093100. When plugged in I can hear power, however it does not run. I go to various cycle on the cycle switch nothing happens. Can I have some advice as to what the problem is, so I can repair it.
aloha Robert The advice I recieved to Repair my Lady kenomre was right on. My Lady is running fine. Thanks Robert
Great, glad that worked and thanks for updating us.
