Discuss
Help
 in
Washer Repair
A few loads ago Washer originally started making a very load screaching noise in spin cycle......now it also makes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help
  #1 (permalink)
Old 01-01-2008, 08:42 AM
MarkD MarkD is offline
Junior Member
MarkD is on a distinguished road
Default Help
Model Number: pav1000aww   Brand: Maytag   Age: 5 - 10 years
A few loads ago Washer originally started making a very load screaching noise in spin cycle......now it also makes noise (though not as loud) when in wash cycle. I checked your blog site first and ruled out the following.......Belt is in good shape; washer drains fine; motor pulley turns smooth and freely; transmission pulley (big wheel) turns freely one way and has resistance the other. The pump pulley turns but not smooth at all.....checked the pump out - no clogs. Even apart the pump pulley is very rough turning............should the pump pulley turn smoothly. Do you think its the pump pulley (pump) that needs to be replaced.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-01-2008, 09:12 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default pump
yes the pump should turn easy. with no noise
  #3 (permalink)
Old 01-01-2008, 09:34 AM
Junior Member
Default
Thank you very much.....Happy new year!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
