Washing machine will not spin. Removed bolt from agitator. Should drum be removed to see if something is in the pump?
Originally Posted by: kcrepair Washing machine will not spin. Removed bolt from agitator. Should drum be removed to see if something is in the pump? Need information on how to remove the drum.
