Discuss
Washer will not drain or spin
 in
Washer Repair
i purchased this washer used 5 months ago and has been running great until today. i ran it and a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not drain or spin
  #1 (permalink)
Old 12-31-2007, 05:01 PM
fenderi fenderi is offline
Junior Member
fenderi is on a distinguished road
Default Washer will not drain or spin
Model Number: LSQ9110PW2   Brand: Whirlpool   Age: 1 - 5 years
i purchased this washer used 5 months ago and has been running great until today. i ran it and a while later i checked back on it and there was water in it but it would not drain. so i did an internet search on this issue and it stated it was either a clogged sewer hose or the water pump. so i diagnosed that it wasn't the sewer hose (external) and is probably the water pump. but just for giggles i tried running the spin cycle (with the lid closed and the unit plugged in of course) and it would not spin nor run. so i wonder if the motor blew since the water pump is motor driven?? i don't think it's the dials or anything as it does fill up with water if i tell it to. ideas? thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 06:41 PM
techray techray is offline
Junior Member
techray is on a distinguished road
Default
FEDERI : It sounds like your lid switch is not being actuated. It acts as if the lid was open. In some cases if you press down hard on the lid and it spins, it may just be a bent arm on the hinge hook that actuates the lid switch under the panel. its either the bent hinge hook or the lid switch it sounds like.
  #3 (permalink)
Old 01-19-2008, 09:49 AM
Junior Member
Default
techray you are a good one.... i looked and the lid switch is completely burnt out. there is black residue everywhere. the terminal melted to the lid switch. i was able to disconnect the two, is there a way i can just bypass the lid switch?? thanks
  #4 (permalink)
Old 01-19-2008, 10:17 AM
Junior Member
Default fenderi
it is not recommended to bypass a lid switch, as it is a safety feature that stops the machine from spinning when the lid is opened. It is best that you replace the lid switch and avoid any possible injury and have the unit work the way it is designed. The lid switch is not very expensive nor hard to replace. Most parts Distributors have that part in stock. If you need assistance in replacing the switch please feel free to reply. Id rather see you do that then bypass something that could create another issue. The part number for the lid switch that you need is 818084. The lid switch as you probably already know is under the control panel on the left hand side.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't drain or spin, Bad timer? myrdynn Washer Repair 2 12-31-2007 06:48 AM
Help!! Washer Want Drain Or Spin rpearce Washer Repair 2 12-14-2007 04:37 PM
washer will not spin or drain Martha Shelby Washer Repair 2 10-25-2007 03:43 AM
washer will not spin or drain Martha Shelby Washer Repair 1 10-24-2007 04:59 AM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 07:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
