Discuss
Hot water won't stop running into washer
 in
Washer Repair
I have a 6.5 yr old Kenmore washer - model #23812100. Problem: the hot water will not stop running into
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Hot water won't stop running into washer
  #1 (permalink)
Old 07-01-2009, 02:05 PM
Junior Member
roseblock is on a distinguished road
Default Hot water won't stop running into washer
Model Number: 23812100   Brand: Kenmore   Age: 5 - 10 years
I have a 6.5 yr old Kenmore washer - model #23812100. Problem: the hot water will not stop running into the tub. All other cycles work fine. Normally, when you push the Cycle Selector Control knob in the water will shut off. At this time, when you push the control knob in the cold water will stop but the hot water will continue to run into the tub of the machine. Also, water ran out from under the machine onto my floor.
Is this due to the constant running of water into the tub? Is there a part that would eliminate the problem of the hot water not shutting off? Does it have something to do with the Cycle Selector Control Knob? The water continues to run during all cycles. The spin cycle works fine.
Ads By Google
Related Models
Whirlpool 2382W00
Whirlpool 2382W1A
Whirlpool 2382W2A
Whirlpool 2382^00
Whirlpool 2382^1A
Whirlpool 2382^2A
Whirlpool 2384W0A
Whirlpool 2384W1A
Whirlpool 2384W2A
Whirlpool 2384W3A
Whirlpool 2384^0A
Whirlpool 2384^1A
Whirlpool 2384^2A
Whirlpool 2384^3A
Jenn-Air 2385EGN Surface Unit - Ddraft Ele
Jenn-Air 2385EGS Surface Unit - Ddraft Ele
Jenn-Air 2390ERS Surface Unit - Ddraft Ele
Whirlpool 2406W0A
Whirlpool 2406W1A
Whirlpool 2406W2A
Whirlpool 2406W3A
Whirlpool 2406^0A
Whirlpool 2406^1A
Whirlpool 2406^2A
Whirlpool 2406^3A
Whirlpool 2413W0A
Whirlpool 2413^0A
Whirlpool 2414W0A
Whirlpool 2414W1A
Whirlpool 2414W2A
Whirlpool 2414^0A
Whirlpool 2414^1A
Whirlpool 2414^2A
Whirlpool 2424W0A
Whirlpool 2424^0A
Whirlpool 2424^1A
Whirlpool 2426W0A
Whirlpool 2426W1A
Whirlpool 2426W2A
Whirlpool 2426^0A
Whirlpool 2426^1A
Whirlpool 2426^2A
General Electric 24488L0 Electric range
General Electric 24488W0 Electric range
Whirlpool 2453W0A
Whirlpool 2453W9A
Whirlpool 2453WAA
Whirlpool 2453^9A
Whirlpool 2453^AA
Whirlpool 2454X0A
Whirlpool 2454X1A
Whirlpool 2454X2A
Whirlpool 2454X3A
Whirlpool 2456X0A
Whirlpool 2456X1A
Whirlpool 2456X2A
General Electric 24588B0 Electric range
General Electric 24588L0 Electric range
General Electric 24588W0 Electric range
General Electric 24688B0 Electric range
General Electric 24688L0 Electric range
General Electric 24688W0 Electric range
Amana 2474.000 Mwave - Family Size (60 Hz)
Jenn-Air 2475 Surface Unit - Ddraft Ele
Jenn-Air 2475N Surface Unit - Ddraft Ele
Jenn-Air 2475S Surface Unit - Ddraft Ele
Amana 2476.000 Mwave - Family Size (60 Hz)
Jenn-Air 2480 Surface Unit - Ddraft Ele
Jenn-Air 2480N Surface Unit - Ddraft Ele
Jenn-Air 2480S Surface Unit - Ddraft Ele
Jenn-Air 2485 Surface Unit - Ele
Jenn-Air 2490 Surface Unit - Ele
Amana 2492.000 Mwave - Family Size (60 Hz)
Whirlpool 2492L0A
Whirlpool 2492L1A
Whirlpool 2492X0A
Whirlpool 2492^0A
Whirlpool 2492^1A
Amana 2494.000 Mwave - Family Size (60 Hz)
Amana 2494.001 Mwave - Family Size (60 Hz)
Amana 2494.A Mwave - Family Size (60 Hz)
Amana 2494.C Mwave - Family Size (60 Hz)
Amana 24940.A Mwave - Family Size (60 Hz)
Whirlpool 2496X0
Whirlpool 2496X1
Whirlpool 2496X2
Whirlpool 2496^0
Whirlpool 2496^0A
Whirlpool 2496^1
Whirlpool 2496^1A
Whirlpool 2496^2
Whirlpool 2496^2A
Amana 24C3SS Room Air Conditioner
Frigidaire 24CGMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN2 Tap(v2) / Gas Range
Frigidaire 24DEMBWAD4 Tap(v1) / Electric Range
Magic Chef 24FA-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FA-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FA-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FB-6CKXW
Magic Chef 24FG-6CKXW
Magic Chef 24FK-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FK-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FK-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FN-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FN-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FN-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FS-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FS-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FS-6CKXWV8-DY Range - S/c Mwave Gas
Magic Chef 24FV-6CKXW
Magic Chef 24FY-6CKXW Walloven - S/c Dbl Oven Gas
Magic Chef 24FY-6CKXWV8 Range - S/c Mwave Gas
Magic Chef 24FY-6CKXWV8-DY Range - S/c Mwave Gas
Frigidaire 24HA241
Frigidaire 24HA241A
Frigidaire 24KEMAWAD3 Tap(v1) / Electric Range
Frigidaire 24KEMAWAD4 Tap(v2) / Electric Range
  #2 (permalink)
Old 07-01-2009, 02:23 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Select hot/hot or warm/warm and start a cycle. As it's filling, unplug machine. If it continues to fill after the machine is unplugged, you'll need to replace the water inlet valve. Remember to shut off water at th source, and unplug the machine before making any repairs.
  #3 (permalink)
Old 07-01-2009, 02:34 PM
Junior Member
Default Replace water inlet valve
Is the water inlet valve difficult to replace on my washer? Thank you for your speedy response!
  #4 (permalink)
Old 07-01-2009, 02:41 PM
Senior Expert
APP Volunteer
Default
It isn't so difficult that the average person can't do it. If you know your way around a screwdriver and a wrench, you can do it. We'll talk you through the steps.
  #5 (permalink)
Old 07-06-2009, 05:30 AM
Junior Member
Default water mixing valve
How do I gain access to the water mixing valve. I don't see any screws on the front of the consol like some older washers. There are several screws and plastic clips on the back of the machine panel. Don't know where to start ! Thanks
  #6 (permalink)
Old 07-06-2009, 06:10 AM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Look on the back where the water hoses go into the back. That's where the valve is.
  #7 (permalink)
Old 07-06-2009, 09:42 AM
Senior Expert
APP Volunteer
Default
Here's a link to a Youtube video describing the access you're seeking.
YouTube - Washer Appliance Repair Help Video
  #8 (permalink)
Old 07-06-2009, 04:50 PM
Junior Member
Thumbs up Installed water mixing valve
With your help, the new water mixing valve was installed on my washer without any problems! Thank you SO much for your help !
  #9 (permalink)
Old 07-06-2009, 09:04 PM
Senior Expert
APP Volunteer
Default
Well done! I'm glad you got it.
  #10 (permalink)
Old 05-23-2010, 02:42 AM
Junior Member
samsgirl06 is on a distinguished road
Talking Yay!!!
I was looking through google desperatley to find a way to fix the washers problem that I had NO idea about nor did I have the slightest inclination of what was wrong. I found this answer at 439am and my washer is fixed , happened to have an old one that had the part I needed! Lucky me huh!! So I had to register here just to say thank you so much for all the good answers!! And not even my question! Yes, Im a but excited and got carried away with the (!!!!!!!!) lol thanks again, Brandell Kays
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cold water won't stop running on my Whirlpool Top Loading Washer! tm3191951 Washer Repair 11 07-30-2010 06:49 PM
Washer machine water won't stop running jrciii Washer Repair 1 10-22-2009 06:29 PM
Water does not stop running ken Kowalsky Refrigerator & Freezer Repair 1 09-17-2009 09:12 AM
washer wont stop running water above_that2002 Washer Repair 2 12-05-2008 08:32 PM
Cold water will not stop running tacohead59 Washer Repair 7 08-01-2008 04:06 AM
