I have removed this pully out of my washer as it wasn't turning the tub. As it turns out the belt was off and pully was loose. I was able to turn the pully bolt with my hand. However, I looked at this pulley, it doesn't seem to have any "lip"...simliar to the ones on the rims of a car. Instead of just tightening the bolt and put the belt back, I was wondering if this pulley is still good. Attached is a picture of the pulley: Any suggestions would be appreciated..thanks. (i can take more pics if needed) Fong
This pulley isn’t supposed to have a lip. I can’t see anything wrong with the pulley. Put it back on and tighten it good. Clothes Washer Repair Guide
