Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Samsung WF316BAC/XAA no power (http://forum.appliancepartspros.com/washer-repair/390168-samsung-wf316bac-xaa-no-power.html)
ecocars 12-22-2011 10:48 AM
Washer machine has no power? outlet is good but machine is dead, there is a circuit board mounted on the rear panel inside a white plastic piece with a cover over it that the wires from the plug go to via the noise filter. Could this be what I need? if so what is the part # so I can order it and get my clothes washed : )
sidfink43 12-24-2011 08:20 AM
The normal diagnosis for your problem is a failure of the control unit, but I would check all the connections first and check the wiring for breaks or problems.
APP doesn't seem to carry parts for this model (and we who respond on this Forum are volunteers and not associated with APP operations) so I can only suggest you contact them after the holidays and see what they recommend.
You might also have to go to another source that specializes in parts for Samsung.
Sorry not to be of greater help, good luck.
