Discuss
Washing Machine timer
 in
Washer Repair
I believe that if the lid switch on your washer was bad it would still fill and wash. That is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing Machine timer
  #11 (permalink)
Old 07-03-2009, 05:49 PM
applianceman applianceman is offline
Senior Member
applianceman is on a distinguished road
Default
I believe that if the lid switch on your washer was bad it would still fill and wash. That is how most Whirlpools are. The lid switch would stop just stop if from spinning.
  #12 (permalink)
Old 07-03-2009, 06:00 PM
Senior Member
Default
I took a look at the diagram to confirm and your washer would still fill and wash if the lid switch were bad.
  #13 (permalink)
Old 07-03-2009, 07:37 PM
betthinks betthinks is offline
Junior Member
betthinks is on a distinguished road
Default wahing machine timer
Quote:
Originally Posted by betthinks View Post
Thanks so much. I got the same message from someone else who knows washers, so it seems we are back to the lid switch. He said if it failed, the machine would shut down and not operate at all.. Do you agree?
Originally, the machine filled and agitated, then stopped. The lid switch had come apart, we discovered when we opened the cabinet. When the pole hit the switch, it sort of "fell down" under the top. My friend put it back together, used a tiny amount of heavy duty glue to hold it together, screwed it back on and we left it to dry. Later we went and tried the switch to see if it was working again, and nothing. No power at all. The appliance guy I talked to said something about the clear tube running from the switch under the top, and said if that part failed, it would shut the machine down. Does that make any sense?, given the way it first acted?
Thanks for answering. I really appreciate the education. I cannot afford to call a repairman, so I am trying to figure this out myself. Betty Hinks
  #14 (permalink)
Old 07-03-2009, 08:28 PM
Senior Member
Default
With this new info now I would recommend changing the lid switch. I had no idea it came apart like that on you. At the very least you know the lid switch is bad so change that first hopefully that will be the only problem.
  #15 (permalink)
Old 07-04-2009, 04:24 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You can put a jumper wire between the two outer pins of the lid switch connector located behind the control panel.Then see if it works.The clear tube to the switch is for mechanical support of the wires, no electrical function at all.
__________________
  #16 (permalink)
Old 07-05-2009, 10:31 AM
Junior Member
Default washing machine timer
Thank you so much. I kind of wondered about the "tubing" thing. I have ordered a new lid switch and we give that a try. Let's hope that is the problem. Thanks again. Betty Hinks
  #17 (permalink)
Old 07-05-2009, 03:43 PM
Senior Member
Default
Let us know how you make out.
For do-it-yourself appliance repair visit Appliance Repair Guide For All Major Home Appliances
  #18 (permalink)
Old 07-09-2009, 05:59 PM
Junior Member
I got the new lid switch and installed it, but no luck. The machine simply will not respond to being turned on. No fill, no agitation, no nothing. What would be the next best thing to check? Betty Hinks
  #19 (permalink)
Old 07-09-2009, 06:29 PM
bad thad bad thad is offline
Junior Member
bad thad is on a distinguished road
Default
I have the same problem, anxious to find out what the answer is!
  #20 (permalink)
Old 07-09-2009, 07:20 PM
Senior Member
Default
If you do not have a loose wire I would say that the timer is bad even though we have been saying they don’t go bad often.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine LILDAD Washer Repair 1 06-06-2009 11:06 AM
Sears washing machine timer JKB1 Washer Repair 1 05-29-2009 03:37 PM
Washing machine titoac Washer Repair 1 05-29-2009 01:26 PM
washing machine juliejez Washer Repair 1 03-24-2009 09:19 PM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 03:42 AM
