on any of the four cycles the washer will not fill up with water and wash but when you turn it to the rinse or spin cycle it will work fine what could be the problem? thanks for your help:mad:
If your timer is metal, remove the cover and clean the contacts with a non-residue cleaning spray available at Lowes. Turn the timer while spraying.
