Discuss
Washer makes grinding noise. wont spin
 in
Washer Repair
Kenmore Top load. was washing rugs when it went out of balance. reset load and now it just makes a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer makes grinding noise. wont spin
  #1 (permalink)
Old 12-31-2007, 09:30 AM
montanaJohn montanaJohn is offline
Junior Member
montanaJohn is on a distinguished road
Default Washer makes grinding noise. wont spin
Model Number: 11025852400   Brand: Kenmore   Age: 1 - 5 years
Kenmore Top load. was washing rugs when it went out of balance. reset load and now it just makes a grinding noise
Related Models
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026814690 WASHER
Kenmore 11026822690 WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
Kenmore 11026842694 AUTOMATIC WASHER
Kenmore 11026844690 WASHER
Kenmore 11026844694 AUTOMATIC WASHER
Kenmore 11026892690 TB26-10- WARM RINSE
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
Kenmore 11026902692 AUTOMATIC WASHER
Kenmore 11026904692 AUTOMATIC WASHER
Kenmore 11026912690 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Sears 11027802691 AUTOMATIC WASHER
Sears 11027812690 AUTOMATIC WASHER
Sears 11027812691 AUTOMATIC WASHER
Sears 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Sears 11027824790 AUTOMATIC WASHER
Sears 11027852790 AUTOMATIC WASHER
Sears 11027852791 AUTOMATIC WASHER
Sears 11027862790 AUTOMATIC WASHER
Sears 11027892790 AUTOMATIC WASHER
Sears 11027892791 AUTOMATIC WASHER
Sears 11027894790 AUTOMATIC WASHER
Sears 11027894791 AUTOMATIC WASHER
Sears 11027902790 AUTOMATIC WASHER
Sears 11028299890 AUTOMATIC WASHER
Kenmore 11028802890 AUTOMATIC WASHER
Kenmore 11028803890 AUTOMATIC WASHER
Kenmore 11028812790 AUTOMATIC WASHER
Kenmore 11028822790 AUTOMATIC WASHER
Kenmore 11028822791 AUTOMATIC WASHER
Sears 11028824790 AUTOMATIC WASHER
Kenmore 11028824791 AUTOMATIC WASHER
Kenmore 11028872890 AUTOMATIC WASHER
Kenmore 11028872891 AUTOMATIC WASHER
Kenmore 11028874890 AUTOMATIC WASHER
Kenmore 11028874891 AUTOMATIC WASHER
Kenmore 11028882790 AUTOMATIC WASHER
Kenmore 11028882791 AUTOMATIC WASHER
Sears 11028884790 AUTOMATIC WASHER
Kenmore 11028884791 AUTOMATIC WASHER
Kenmore 11028892790 AUTOMATIC WASHER
Kenmore 11028892791 AUTOMATIC WASHER
Sears 11028894790 AUTOMATIC WASHER
Kenmore 11028894791 AUTOMATIC WASHER
Kenmore 11028902790 AUTOMATIC WASHER
Kenmore 11028902791 AUTOMATIC WASHER
Kenmore 11028912790 AUTOMATIC WASHER
Kenmore 11028912791 AUTOMATIC WASHER
Sears 11028922790 AUTOMATIC WASHER
Kenmore 11028922791 AUTOMATIC WASHER
Sears 11028924790 AUTOMATIC WASHER
Kenmore 11028924791 AUTOMATIC WASHER
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
  #2 (permalink)
Old 12-31-2007, 10:15 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull the pump and motor and check the coupler, probably broken.
__________________
  #3 (permalink)
Old 01-01-2008, 02:25 PM
Junior Member
Default
Thanks, right on the money
  #4 (permalink)
Old 01-21-2008, 07:52 PM
cjwdoyle cjwdoyle is offline
Junior Member
cjwdoyle is on a distinguished road
Default
I think that is exactly what the problem is. We just replaced this part cost under $17.00. Here is a link to a site that gives detailed instructions even with pictures of how to do this.
Sears Kenmore Washing Machine Repair
My husband did the repairs and said it was really simple. We had this same problem 2 or 3 years ago and the repair man charged us $164.00. He said the problem was caused by overloading or things getting off balance which sounds like what happened to you. Good luck.
  #5 (permalink)
Old 11-01-2009, 08:35 PM
timhnelson timhnelson is offline
Junior Member
timhnelson is on a distinguished road
Default Perfecto!
Gentlemen,
Just had this sound occur to my machine this afternoon. Needless to say the unit is over 10 years old and I just figured that I'd have to replace it. While at it, you know you may as well replace the dryer too. Gotta keep the wife happy. Anyways, followed the instructions on the linked site and sure enough, it appears to have been the coupling. I found the part and will pick it up tomorrow. $20 is much better than $1600!
Great forum!
  #6 (permalink)
Old 11-02-2009, 02:37 AM
Senior Expert
APP Volunteer
Default
If it happens again, do the tranny coupler test in my "sticky" above, "replacing direct drive brake shoes"
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Scottmcc Washer Repair 6 01-05-2008 08:24 AM
Washer makes noise and does not spin rjr Washer Repair 1 12-30-2007 03:08 AM
Grinding noise from washer jreynolds Washer Repair 2 12-27-2007 03:05 AM
Washer won't complete cycle-grinding noise rebekah Washer Repair 2 12-13-2007 08:20 PM
