My washer first gave me the error PF. I cleared that out then got the SD error and the water drained all over the floor. I purchased and installed a new water pump due to that being where the water was coming from. It ran fine for a empty test run but then I did a load of laundry and again, it drained all the water on the floor and gave me the error code of LS. The clothes were dripping wet still. Why is it still draining all over the floor and what do I do to get it to drain right?? I am very frustrated and can't seem to find anyone who is having the same issue of it draining all over the floor. Any help would be VERY MUCH appreciated!!
